Author Topic: TS100 doesn't function properly when earthed  (Read 58330 times)
Offline TheBay
  • Country: wales
Re: TS100 doesn't function properly when earthed
« Reply #100 on: October 17, 2018, 12:26:53 pm »
I bought a TS100 because it was on offer, I paid £30 for the "Brown" upgrade version with a couple of tips.
Handy for portable use etc and can use on a home made battery pack.
It's a great iron, however I think some are missing the point with this iron, paying £50 or more for it then another £50+ on power supplies and things,
this no longer becomes good value for money and the money would be better invested in a soldering station instead, especially if it's used just on the bench.
And then there is taking in to consideration the intricacies of its quirks regarding grounding.
« Last Edit: October 17, 2018, 12:29:36 pm by TheBay »
Offline kaevee
  • Country: in
« Reply #101 on: October 17, 2018, 12:36:16 pm »
You are right. Silly of me suggesting a $50 power supply!  |O
Offline epigramx
« Reply #102 on: December 09, 2018, 11:25:00 pm »
I don't understand something about the conclusions in this thread. It is suggested that all is well if a properly grounded DC supply has its negative connected to the ground of the device.
OK so far. Now, I wonder, wouldn't be all OK if one directly grounded the negative and the device manually? (I mean even if the PSU is cheap and non-grounded initially)
Offline Gyro
« Reply #103 on: December 11, 2018, 11:59:06 am »
Best Regards, Chris
Offline coolyota
« Reply #104 on: May 06, 2019, 09:08:04 am »
Hello, I am contemplating buying TS100. I currently have a 3 prong laptop PSU, is it safe to use with the TS100 providing ground? Sorry newby question...
Offline djnz
« Reply #105 on: June 26, 2020, 07:32:59 am »
For those considering power bricks:
MeanWell GST series does not have -ve DC output connected to earth ground and should be avoided for the TS100.
The medical grade GSM B series is only 2 pin so do not get that either.
However the medical grade GSM A series does have -ve DC connected to earth ground, so that is good.
I think the MeanWell GSM90A24-P1M should be good.
The following users thanked this post: MacMeter
