The usual plants can use red and blue light. They look green because the green is not used.
So special lamps can have some efficiency advantage, but normal white LEDs are also not that bad, as they also have a maximum in the blue and phosphore part somewhere in the red / yellow. The low CRI lamps often have reduced green anyway.
Most plants can not actually use the full intensity of the sun and there is no real need to get the full intensity of the sun light.
