Author Topic: What are the chances these are real?  (Read 2310 times)
Offline BillyOTopic starter
« on: May 16, 2024, 02:48:21 am »
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline Kim Christensen
Re: What are the chances these are real?
« Reply #1 on: May 16, 2024, 05:11:03 am »
You can buy LM741 from Digikey... So why bother with eBay?
Offline pcprogrammer
« Reply #2 on: May 16, 2024, 05:35:38 am »
Or if you like the gamble you can get them cheaper on Aliexpress.
Edit: And the the IC's the ebay picture shows are 8 pin dip and not 14 pin dip like the title offers (LM741J-14) Those are harder to find on Aliexpress and more expensive, but less than the single piece in that ebay add.
« Last Edit: May 16, 2024, 05:40:01 am by pcprogrammer »
Offline Haenk
« Reply #3 on: May 16, 2024, 09:30:59 am »
Judging by the negative feedback, they *do* sell fakes. I therefor would consider positive feedback rather as "the buyer did not notice the fake".
So expect to receive not the stuff you purchased. Buying OPAMPs from China is pointless.
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #4 on: May 16, 2024, 10:35:11 am »
Because these are from '88 and some people will only accept era-correct replacements?  ;D
« Reply #5 on: May 16, 2024, 02:17:19 pm »
Sure you can, if you want LM741C, but the one I linked to is the LM741J.  The 741C is just the run-of-the-mill 36V part.   The 741J is the mil-spec 44V part.  You also can get the LM741J from Digikey too, but it's 5 times the price of the one I linked on eBay.
When you need 44V, 36V just won't do.
« Reply #6 on: May 16, 2024, 02:21:37 pm »
Yeah, don't know what's up with that.  Kind of has "pass on this" all over it.  a 14 pin version will not fit the available space. :-DD
« Reply #7 on: May 16, 2024, 03:37:22 pm »
True, but if I needed 44V specs, I'd simply buy a different OpAmp rather than the LM741J...
I can see the case for keeping retro equipment as close to stock as possible. But for everything else, I'd find a more modern OpAmp.
« Reply #8 on: May 16, 2024, 04:26:19 pm »
I need a DIP-8 package.  I guess I could get some other 44V OpAMp and use a carrier/breakout board.  But none of them are cheap either and then you have the expense of the chip carrier and the additional work (not so bad tho..).
Offline Shock
« Reply #9 on: May 16, 2024, 06:19:14 pm »
Looks cheaper ordering directly from TI.
Buying a nos military spec part from china on ebay is laughable.
« Last Edit: May 16, 2024, 06:30:01 pm by Shock »
« Reply #10 on: May 16, 2024, 06:29:15 pm »
Once you include shipping costs (I'm in Canada) it's not that much less.  My best bet is to wait until I have enough to order from digikey so that I get free shipping.
« Reply #11 on: May 16, 2024, 07:48:11 pm »
If you can find a carrier/breakout board for cheap (Could also design/order a custom one from JLCPCB), then something like the TJM4558CDT could work unless you need the offset null pins from the 741...
Offline BrokenYugo
« Reply #12 on: May 16, 2024, 08:03:11 pm »
The op amps in particular are virtually all fake on Chinese marketplace sites, if they;re working opamps they won't match the datasheet for the part number. With ceramic package ICs you might have better chances to get the real thing, but it's going to be a beat up used part, exposed to ESD, solder dipped legs, etc. low grade salvage of last resort.
Offline thm_w
  • Non-expert
« Reply #13 on: May 16, 2024, 09:07:34 pm »
smd to thr adapter boards are incredibly cheap, pennies: https://www.aliexpress.com/item/1005002776733692.html
Is this a design or a repair. If its a design you've possibly painted yourself into a corner with all these niche specs, that may or may not be needed.
« Reply #14 on: May 17, 2024, 12:09:55 am »
It's neither and both.
I'm trying to get one of those half baked Highland power supplies working properly.  It's easy enough to limit the current through the pass transistor to get it in spec but then you are still faced with the op-amps being supplied too much voltage.  The original design calls for TL081 for all 3 of them.  However, the current error amp and the voltage error amp are being supplied with as much as 40V when current draw is low.  The voltage refence is okay and the voltage error amp requires offset adjustment.
Options:
  • Exchange the 2 over run OpAmps for LM741J - simple but more costly
  • Run the positive supply for the current error amp from the 24V fan regulator and just replace voltage error amp with a LM741J - a bit more work, but cheaper
  • Just use a 20V transformer (instead of 24V), adjust the gain of the voltage error amp to give 25V full-scale and use cheap TL081s all round and end up with a 0-25V and 2mA to 3A power supply - cheaper and simple but only a 75W supply instead of a 90W supply
I think I will go with option #3.   :phew:
Offline thm_w
  • Non-expert
« Reply #16 on: May 17, 2024, 12:33:30 am »
Some discussion here:
https://forum.allaboutcircuits.com/threads/power-supply-kit-supply-voltage-on-tl081.128351/
https://electronics.stackexchange.com/questions/520653/how-to-find-a-pin-to-pin-replacement-for-tl-081-but-with-higher-vcc
Maybe the negative rail voltage can be reduced?
That's option 4 and not too hard to do, but you'd still need a negative rail of about 3V so that would just save 2V - not really enough but would certainly extend the life of the OpAmps.  You'd still have to deal with pass transistor.  The operating envelope has the possibility of it dissipating 100W.  That's it's AMR.  SO all in all a PS living on the edge.  I'd like to have it "safe at all possible speeds" (Sorry Ralph)  :-DD
Offline temperance
« Reply #17 on: May 17, 2024, 01:06:25 am »
So you don't want a genuine LM741 from some reputable distributor but a fake LM741 ebay because it says mil-spec :-DD
This is probably the best joke ever posted in here.
« Reply #18 on: May 17, 2024, 01:15:46 am »
Is this the winner of the Dunning-Kruger award?
No.  The LM741J IS the mil-spec part.  Whether I get it for $5 or $30.  If I can get it from Yun Hung-Lo for $5 and it's genuine, then why not?  They have been making these for 4 decades or more, so presumably there is some cheaper NOS around somewhere.
So, no, I'm not considering buying it from the eBay ad because they say "mil-spec",  but I'm considering it because it's an LM741J.   :palm:
Shall we await your next silly, un-researched and self-embarrasing outburst, or are you done for the night?
« Last Edit: May 17, 2024, 01:35:18 am by BillyO »
Offline exmadscientist
  • Technically A Professional
« Reply #19 on: May 17, 2024, 02:01:59 am »
The newish TL081H is good to 42V abs max and might be worth considering. (SMD only, though.) Those on DIP adapters plus a 40V-ish zeners across their supply pins might be a reasonable quick fix.
Offline temperance
« Reply #20 on: May 17, 2024, 04:32:48 am »
Beware, here is the next outburst. I did read what you wrote looking for clues as to why you would consider a probably fake mil-spec op amp from ebay but could find a valid argument.
Just calculate the cost of buying fake op amps including your additional work. It doesn't make sense.
-2 or 3 fake op amps @ $4.5 each.
-Soldering them into the board.
-It doesn't work. Darn, is it the op amp or did I make a mistake? Time for some debugging. The op amp are fookin fake. I've been ripped off.
-Desolder the op amp.
-Search for a proper solution.
-Back to square one. Angry now.
-Order parts.
-Solder in new solution.
-It works but those suckers ripped me of. Must complain somewhere about that. Didn't get my money back.
https://www.digikey.ca/en/products/detail/dfrobot/FIT0290/6588424
SMD to DIL for about 80 cent including pin headers combined with an MC33072ADR2G for about 62 cent will do the job. And in SO8 I will probably find more 44 V capable op amps.
« Last Edit: May 17, 2024, 01:05:18 pm by temperance »
Offline ledtester
« Reply #21 on: May 17, 2024, 05:17:19 am »
In this blog post:
https://www.paulvdiyblogs.net/2015/05/tuning-030v-dc-with-03a-psu-diy-kit.html
the author uses TLE2141's which have a 44V operating range.
In the comments someone mentioned using a MC34071.
Here's another forum thread on that circuit:
https://www.eevblog.com/forum/beginners/0-30v-0-3a-psu-audiogurus-version/
« Last Edit: May 17, 2024, 05:19:28 am by ledtester »
Offline tooki
« Reply #22 on: May 17, 2024, 09:33:01 am »
I don’t think Dunning-Kruger means what you think it means…
They weren’t disputing that the LM741J is the mil-spec part. They’re pointing out how incredibly naive it is to believe you’d actually get one from a vendor in Shenzhen at a fraction of the real price. The listing isn’t even consistent in what it’s for — the listing details say “OP497GSZ” (a completely different op amp).
Of course there’s a (technically nonzero) chance the seller actually has legit parts, but it’s really unlikely.
They weren’t the ones responsible for a “silly, un-researched and self-embarrasing outburst”, that would actually be you…
« Reply #23 on: May 17, 2024, 05:43:24 pm »
So instead you thought it best to ridicule me?  Nice.
« Reply #24 on: May 17, 2024, 06:01:51 pm »
So, I can tell from the rest of your post that reading comprehension may not be your strong suit, but it is interesting nonetheless.
At what point in this thread did I actually state a belief that I could get a real LM741J from the ebayer I posted a link to?  In fact I think it's fairly obvious I was making light of something I found in an ebay search.
But just let me ask a question.  Does it make you feel better about yourself to try to belittle someone on the internet, just because you cannot grasp the gist of their comments, by calling them naïve?
You and temperance.  Big people.  Nice people for sure.  :-+
