Edit: now bought Amscope SM-3NTP which is the SM745NTP plus single boom stand
I know there's a ton of which microscopes should I buy threads out there, but hopefully mines a little different
In December I purchased the Swift S41. This has good reviews for an entry level microscope
On Daves mailbag blog 1209 (starting approx 14:00) he also gives it the thumbs up
https://youtu.be/IKHg32o8rRg and the forum entry for his blog in the comments, those that have purchased it, also seem happy.
https://www.eevblog.com/forum/blog/eevblog-1209-mailbag/.
Last week, I was attempting a repair of a PS4. While the quality of what I see through the microscope is good, I found it a real pain to use. The main reason being that I simply couldn't turn the circuit board to the position I wanted as it kept hitting the stand.
If you see the attached pic, this is what I had to do in order to get some of the positions I wanted, still couldn't get it at a perfect angle. And in order to do this, I had to place my multi meter on the stand to stop the microscope tipping over.
The other little annoyance was the small field of view (but I don't know how more expensive ones compare)
I'm currently in the position where I have some disposable income, and I'm seriously thinking about getting a microscope around the £500 - £700 range.
But, before I spend this sort of money, I want to know what sort of difference I can expect by upgrading.
And then there's the how long is a piece of string question. Amscope seems to be the make most people use, I go to their US site, put in Trinocular and I have 1953 results.
After watching a few youtube vids, I think 3.5 to 45 is ample, that cuts it down to 99 single and 40 double boom arm ones to choose from.
Telling it I don't want a camera (can always get one later if I desire) gives me a much better 8 single and 6 double boom to choose from
And looking at them, I THINK they are all the same, just with different light/rings.
That being the case, does anyone know what sort of difference I can expect from this microscope, and which light ring I should get
Many thanks
