Most soldering stations with auto setback just put a switch inside the stand to detect inactivity. It is a fairly common feature so check the usual people like Pace and Weller.
Yes. But I would like that confirmed. The manual is silent on this topic.
What station are you using at the moment?
The Pace ADS200 uses a configurable timer in the station called
Setback (low power or standby mode) that starts counting when you are not soldering. There is another adjustable timer in the station that will power down the iron after it enters into that Setback mode called
Auto Off (sleep mode). Frequent soldering keeps it out of Setback and therefore Auto Off. A press of a button on the station will wake it out of Setback or Auto Off. Every station comes with these features.
Then if you get the specific
Instant Setback Stand version (a few bucks more) it has an attached cable that connects to the station and you can use it like a on/off switch for sending the iron into Setback or waking it up into operating temp (hardware switched low power/standby mode).
While it's totally unnecessary to have the Instant Setback Stand, you can tin the iron tip and return it to the stand and have instantly power down to 150C (below melt) and put to sleep at room temp soon after without doing anything further. Lift the handle and it's back to temp, in many cases it's so fast you don't see it heat up. So none of this 30-60 secs waiting.
Specs wise, materials and cartridges it obviously eats the Chinese clones.
