Author Topic: SEI branded 10 Mhz quartz oscillator, need help with tech specs  (Read 6271 times)
Offline cio74Topic starter
Hello,
I have got this quartz oscillator, does anyone has any idea about technical specs and pinout?
Thanks.
cio
« Last Edit: June 28, 2016, 03:58:29 am by cio74 »
Offline valgamaa
  • Country: ee
Re: 10 Mhz quartz oscillator, need help with tech specs
« Reply #1 on: June 27, 2016, 04:37:29 pm »
SEI are now known as Rakon, so you could check their website for information.
Offline StillTrying
  • Country: Broken Britain
Online Vgkid
« Reply #3 on: June 27, 2016, 07:04:21 pm »
if it is part of Rakon, good luck on getting specs. I had some ocxo's with date codes of 00-02, and specs are only what you can find online.
Re: SEI branded 10 Mhz quartz oscillator, need help with tech specs
« Reply #4 on: July 01, 2016, 02:29:15 pm »
I couldn't find anything about it.
However, I am keen to see it working, I am thinking to start with say 3.3v voltage, can someone give a hint about the most common pinot layout or there is no such thing.
I pin is tied to the case but the other 3 are not, one is Vcc, one is Output, one may be not connected?
« Reply #5 on: July 01, 2016, 05:33:16 pm »
This is what I get after a little play, 5v Vdc
It does not look like a nice sine wave, any ideas?
Below is the 10Mhz from Anritsu generator terminated in 50ohm, 0dBm
« Last Edit: July 01, 2016, 05:43:31 pm by cio74 »
Offline timb
    • timb.us
« Reply #6 on: July 02, 2016, 01:02:29 am »
That's not abnormal looking. A lot of these oscillators put out what I like to call a "rounded square wave". In fact, that looks pretty good! No ringing, good amplitude. You shouldn't have any problems using that as a clock source.
Offline uncle_bob
« Reply #7 on: July 02, 2016, 02:12:21 am »
Hi
Here's the most basic question:
You can build a 10 MHz XO from scratch for under $5 and you will know what it does. It may well perform better in your application than the unit you have. Since there are no specs on the unit, and not even a fully filled out label .... tough to know what you have or if it was scrapped rather than sold.
So: What *are* you trying to do with the oscillator you have?
Bob
Offline edavid
« Reply #8 on: July 02, 2016, 02:33:40 am »
It might be a 12V oscillator.  I would try increasing the supply voltage a little, and seeing if the waveform improves.  If so, you can (cautiously) take it up to 12V.
« Reply #9 on: July 02, 2016, 08:40:51 am »
It came with a lot of used circuits I bought on Ebay, I don't have any plans to do with it at the moment, just sorting bits and trying to figure out what I *may* do at some point :)
Online Gertjan
« Reply #10 on: July 02, 2016, 09:38:13 am »
Hi Cio74,
You could try to mail Rakon.
I asked them about Rakon TCXO's I have without info, and I found them very helpful.
My contact was Hugh Tucker, email: [email protected]
That fourth pin is probably the VCO input, to fine-tune the frequency....
regards & good luck, Gertjan.
« Reply #11 on: July 02, 2016, 03:21:24 pm »
Thank you, I will certainly email them and see if I get any reply.
Offline Brian of Romsey
« Reply #12 on: April 15, 2018, 08:32:51 pm »
Hi cio,
  Did you work out what the functions of the four pins are and what the optimal operating voltage is?  I ask because I have recently acquired a similar unit:
    QC1206
    Frequency 94.808 MHz
    Serial No. 721559
  Thanks, Brian.
« Reply #13 on: July 12, 2018, 09:25:56 pm »
I finally got round to testing and sorting this oscillator. It does work (which is always a worry for second hand stuff from a radio rally).
At 9.0 Volts it draws between 3 mA and 8 mA on the pin diagonally opposite the ground pin. The output is a sinewave, centred on ground, with an amplitude of 2.9 Volts peak-to-peak when loaded only with the 'scope and 1.8 Volts peak-to-peak when loaded with 50 Ohms.
The pin-out, viewed from above (like normal chips are):
| 4 = Ground ... Out = 3 |
| 1 = N/C .. 9 Volts = 2 |
Strangely my bench PSU seemed unable to deliver a solid supply, loads of ripple - 840 mVolts! Even with a 47 nF polyester & a 470 pF polystyrene right across the pins the ripple only got down to 530 mVolts. Ah well, the output looked like a clean sinewave no matter what.
Cheers, Brian.
« Reply #14 on: July 14, 2018, 03:24:00 pm »
Cheers, Brian.
Offline boelem_b
« Reply #15 on: December 20, 2024, 02:19:13 pm »
Hi, I removed an SEI VCOCXO (Voltage controlled Oven Controlled Crystal Oscillator) from a Marconi TF2171 Synchronizer (goes with a TF2015 signal generator) to use in a GPS disciplined Oscillator.
This has the following spec. (as used in the Marconi unit)
Model nr. 1311A
Output frequency: 5MHz
+5v supply for the oscillator part
+12V supply for the heater part (max. around 0.5A at 12V, but goes down as the unit heats up.)
0-12v for Vctl (control voltage)
Unloaded output at 5MHz is 0.4v-3.1v
Viewed from above (not the pin side):
| pin4 = 5MHz Output                   Vctl  =pin5    +12v= pin3 |
| pin1 = GND                                          +5v Volts = pin2   |
Note I used the pin numbers as in the TF2171 schematic.
