Author Topic: 455kHz bandpass filter for manufacture.  (Read 5511 times)
Offline arildj78Topic starter
  • Country: no
« on: February 05, 2020, 09:30:14 pm »
What would be a good way of designing a 455kHz bandpass filter for manufacture? I've looked at elliptic filter calculators and Analog Devices filter wizard with their multiple feedback active filter. The passband should be as narrow as possible, preferable down to a few hundred Hz, but I'll take whatever I can get.
As far as I can tell I end up with a lot of items on my BOM, just for this filter. Also, the tolerances are killing me! Even with 1% parts, the gain is all over the shop.
A ceramic filter would be nice but apparently they are all end-of-life so I'm not designing in one of those.
Keep in mind that design for manufacture is an important aspect on this one...  Anyone got a suggestion?
Offline Miti
Fear does not stop death, it stops life.
Offline Whales
    • Halestrom
Re: 455kHz bandpass filter for manufacture.
« Reply #2 on: February 06, 2020, 04:00:26 am »
Another possibility:double the freq and use a 1MHz crystal?
  • Country: no
« Reply #3 on: February 06, 2020, 05:48:27 am »
Murata is at end of life on their 455kHz filters. It looks like this is ancient tech, that either no one is using, or is replaced by something else?
  • Country: no
« Reply #4 on: February 06, 2020, 05:49:34 am »
I could double the freq, but my RF is at this frequency, so that would mean adding a LO, mixer and whole lot of stuff...
Offline ezalys
« Reply #5 on: February 06, 2020, 06:24:31 am »
Switched capacitor may be the move.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #6 on: February 06, 2020, 01:34:38 pm »
The modern way would be DSP...
Seven Transistor Labs, LLC
  • Country: no
« Reply #7 on: February 06, 2020, 08:19:17 pm »
How would I even get started with that DSP? I'm currently using a SAMD21 (Cortex M0+) which is probably to lightweight to pull off DSP. Feel free to point me in a general direction both for processor and for literature.
Offline ogden
  • Country: lv
« Reply #8 on: February 06, 2020, 09:06:14 pm »
"For manufacture" means significant volume, right? In such case you ignore what distributors say about product lifetime, contact sales of manufacturer directly and negotiate. DSP approach would be more or less building simple software defined radio (receiver). As there is more than one "DSP approach", would be nice to know - what is your application, what are signal properties & source and what you want to do with filtered signal in the end?
« Last Edit: February 06, 2020, 09:11:50 pm by ogden »
The following users thanked this post: Stewboi
Offline T3sl4co1l
« Reply #9 on: February 06, 2020, 09:26:10 pm »
Hmmm... not sure exactly how much CPU power you need.  A more manageable analog filter might have a bandwidth of 10-20%, in which case you need a sample rate only modestly higher than the center frequency itself.  For which a SAMD21 might actually have enough sample rate out of the box, but you may consider an external ADC for better performance as well.
You'd then need, let's see... you'll want a digital filter to start off, with modest bandwidth, to clean up the band skirts left from the analog filter; this might be a couple IIR filters needing say 4-16 MAC operations.  You want to downconvert (decimate or mix) at some point, which should take a few more MACs and such.  I don't know the exact performance of the SAMD21 but typical ARMs at 100MHz or thereabouts ought to be enough for that, or a little marginal, in which case a more DSP-tuned architecture, or higher clock, would do.
Once it's converted down, you can demodulate directly (direct conversion, implemented digitally), or keep it at a modest center frequency and continue filtering and stuff.  Eventually I guess you'll be demodulating it in whatever way; if that requires a 90 degree phase shift (Hilbert transform), or FFT, you'll probably want something beefier.
You will want to have the ADC output buffered I think, so the DSP operations can be done in blocks.  Interrupt per sample might not be too bad, but it does bring in a fair amount of overhead, and you don't have too much time to spend before the next sample comes in.
If you can reduce the bandwidth at any earlier point, you can of course get by with less CPU power.  A signal of just a few kHz bandwidth could even be handled by an Arduino or PIC, a Cortex M0+ is definitely overkill compared to the minimum possible processing (but, that would require a faster sample-and-hold than an Arduino's ADC can do, and a much tighter analog filter which doesn't save you from the OP problem :P ).
I'm not an expert on digital radio systems, and it may be there are better optimizations.  If nothing else, you can write out the signal chain in exactly the same way you'd solve it analog, then implement the difference functions to solve them in DSP.  That's kind of where I'm approaching this from.
  • Country: no
« Reply #10 on: February 06, 2020, 09:48:43 pm »
I'm measuring the signal strength of a 455kHz CW pulse. The pulse is 180ms long and repeats at about 1Hz. I'm using an RSSI chip to do the detection, so all I need to do is to filter all unwanted signals.
  • Country: no
« Reply #11 on: February 06, 2020, 10:16:33 pm »
freq is 455, required BW 200Hz.
Offline David Hess
  • DavidH
« Reply #12 on: February 07, 2020, 04:22:27 am »
The IF filters required by superhetrodyne receivers cannot be integrated so poorer performing direct conversion receivers have replaced them.
The following users thanked this post: drussell
Offline ogden
  • Country: lv
« Reply #13 on: February 07, 2020, 06:05:41 am »
In such case I would use simplest solution I can imagine: low band-pass "preselector" LC filter (3rd, max 5th order),  synchronous demodulator made out of analog mux. Filtered baseband you slowly sample with ADC (2Ksps or so), then do envelope detector in software. More about sync demodulation here
« Last Edit: February 07, 2020, 12:55:50 pm by ogden »
Offline vk4ffab
« Reply #14 on: February 07, 2020, 12:38:20 pm »
Inrad still make 455khz narrow filters, but you will be paying in kidneys for them. You cant up convert to say 9mhz and build a narrow xtal filter. All current 455khz filters i know of are for am and are 6khz wide, not 200hz.
Offline fcb
    • Electron Plus
« Reply #15 on: February 07, 2020, 12:57:06 pm »
As others have said. 200Hz is to small a BW for convential old school 455KHz IF filters.
I would be looking at either undersampling (see sampling scopes) with your microcontroller ADC, or mixing it down to baseband and sampling, or perhaps switched capacitor bandpass filter (possibly a bit high for this).
Does your signal vary in amplitude over the 180ms window, are you looking for the average over that time?  Required accuracy? What do your interfering signals look like and what level?  Do you have a budget?
You could potentially PLL to the incoming signal and use a lock-in amplifier technique to extract magnitude.
Offline eliocor
    • rhodiatoce
« Reply #16 on: February 07, 2020, 10:12:09 pm »
Maybe this can be of some interest to you: https://www.i2phd.org/armradio/index.html
The following users thanked this post: T3sl4co1l
Offline BigBoss
Offline David Hess
  • DavidH
« Reply #18 on: February 09, 2020, 03:54:57 am »
If you want a narrow 455kHz IF filter that you can buy immediately, you might look for what is available from the manufacturers of amateur radio HF transceivers.  It is a common user installable option.
Offline vk4ffab
« Reply #19 on: February 09, 2020, 08:27:57 am »
They are all pretty much out of production. Inrad is the only one still with production, but for how long is anyones guess. And they are dear as poison. When your b9m starts with 250 bucks for a filter, change your design.
Offline David Hess
  • DavidH
« Reply #20 on: February 09, 2020, 11:35:16 pm »
What I am getting at is that they can be bought as a module directly from Kenwood, Yaesu, Icom, whatever, or from Ebay.  Do a search through their HF radios to see which have narrow 455kHz IF filters as an option.
Obviously this would only work for a small number of units and the cost is high.
For 455kHz, the old school way using a pair or more of slug tuned IF transformers and a variable coupling capacitor might be the best at this point but it requires tuning.  Nothing prevents doing this exclusively with trimmer capacitors and fixed tapped inductors.
Offline KaneTW
« Reply #21 on: February 10, 2020, 02:08:39 am »
Is anything stopping you from doing this in DSP? I'm in a similar boat for a 20MHz video FM receiver with 1MHz deviation and after some fiddling around just decided to do it in DSP.
Offline vk4ffab
« Reply #22 on: February 10, 2020, 03:03:23 am »
Yeah the caveat here is he said its for a commercial product. If your design starts with a $250 part, it better have super high margin, if your design starts with end of life and surplus, you better change your design. There are dozens of ways to get single signal reception that do not require the use of stupid expensive or hard to get parts. Just change the IF frequency to one where you can build a suitable narrow filter or do away with analog entirely and go DSP.
Offline David Hess
  • DavidH
« Reply #23 on: February 10, 2020, 09:50:14 pm »
IF filters are awfully useful to improve in-band rejection of signals which would otherwise overload the following stage.  No amount of DSP can undue overload of the final mixer or digitizer.
As I recall, Rockwell bought Collins' mechanical filter division for exactly this reason and continued to sell mechanical filters to others but of course later shut it down.
If the IF frequency can be lowered, then bandpass switched capacitor filters become viable.
Offline ogden
  • Country: lv
« Reply #24 on: February 10, 2020, 11:01:03 pm »
OP did not even mention specifics of interference, yet you are suggesting most advanced and expensive solution one can imagine. HAM HF rig IF filters are as obsolete as Murata 455KHz ceramic filters, they cost ~ 100x more. I find it inappropriate for knowledgeable engineer to suggest something like that - for application "measuring the signal strength of a 455kHz CW 180ms pulse".
The following users thanked this post: vk4ffab
