Hi Tim:
Thanks for the RDH.
Just above the RDH "Blocking Interference" test is a note that it is not necessary to test with the interfering signal closer than 10 kHz, as the minimum channel spacing at that time was 10 khz.
However the spacing presently on 20 m band for example has the bpsk31 band from 14.070 to 14.073, and the ft8 band only 1kHz above from 14.074 to 14.077.
So correspondingly tougher for a purely analog receiver now.
Hi szoftveres,
Yes, the MVC switch position is pulling the 1stRF grid resistor hard to ground, and the AGC, when selected is rectified from the final IF filter which is +/- 2kHz wide.
My understanding of the desensitization or blocking is now as follows, and it may not be fully correct.
When the interfering signal "wi" mixes with the wanted signal "wf" on the non linear surface representing the anode current as functions of the anode and grid voltage,
there are intermodulation products of 2*wi, 2*wf, and sum and difference wi+wf and wi-wf.
the original frequencies wi and wf remain, but are both reduced in amplitude as part of energy balance before and after the intermodulation.
This effect probably occurs in all RF and IF gain stages, which might be why the RDH manual shows testing on the complete receiver.
As to why the atmospheric noise is also uniformly attenuated by "wi" ( shown by waterfall bands of dark blue all across the band ) I do not know, unless it is due to the same mechanism..
Today's testing after mod to the 1stRF stage yesterday by both reducing its gain, and giving it negative feedback, is showing good results, I think.
It is not possible to quantify due to to varying signal levels, but I can see that the desensitization is reduced, while not eliminated.
This scrot shows two darker bands across the bpsk31 waterfall caused by ft8 stong signals.
https://app.box.com/s/shxv12tthl927n9ocihf27ejbd9j9f28This one was caught by chance, showing a strong cw test signal in band . Note how the waterfall is showing a band of lower level on both the bpsk31 signal and the background noise.
https://app.box.com/s/wyrprtloc7w9z7z9ug3tda4hspovdxpa
