It refers to a book "Accurate Clock Pendulums" chapter "Check your Clock Against WWV", by Robert J. Matthys. It seems to be for pendulum clock testing? TAKE IT APART
A time-nut might like it. "... The Shortt clock, made in the 1920's is the most famous accurate clock pendulum ever known, having an accuracy of one second per year when kept at nearly constant temperature. Almost all of a pendulum clock's accuracy resides in its pendulum. If the pendulum is accurate, the clock will be accurate. In this book, the author describes many scientific aspects of pendulum design and operation in simple terms with experimental data, and little mathematics...
Robert J. Matthys was a Senior Research Engineer at Honeywell, Inc., from 1952 to 1987. He has spent thirty-seven years designing a wide variety of hardware and instrumentation in the fields of electronics, optics, acoustics, mechanics, and photography. In addition, he has spent nine years designing and testing pendulums of various kinds, along with their electronic drive systems and servos, both pulsed and continuous sine wave."
