Author Topic: ADF4351 Harmonic Supression  (Read 3336 times)
Offline spacehenTopic starter
« on: July 05, 2022, 01:26:15 pm »
Hi everyone,
After researching various methods for VHF LO generation (which is being used as the input to a VHF power amplifier), I've been given the impression that it's pretty common to use PLL synthesizers for this purpose. One common PLL synth is the ADF4351. However the problem with this IC is that it produces significant harmonics that need to be filtered.
I want my PA to cover the VHF band from 30MHz to 250MHz. I'm not familiar with harmonic suppression but the most logical method of suppressing these harmonics seems to be designing a LPF to ensure that only the carrier gets through. I would then have to design 3 filters:
  • Filter 1: LPF f0=250 MHz Cutoff
  • Filter 2: LPF f0=125 MHz Cutoff
  • Filter 3: LPF f0=62.5 MHz Cutoff
I am then thinking of switching in the filters with a series of relays. For example if i'm generating 125-250 MHz from the ADF4351 then I would switch in filter 1. I was just wondering if this sounds like a sane design choice and if this is the 'commonly' used method of filtering out harmonics.
Thanks
« Last Edit: July 06, 2022, 01:21:59 pm by spacehen »
Offline radiolistener
  • Country: Earth
Re: ADF4351 Harmonic Supression
« Reply #1 on: July 06, 2022, 09:05:33 pm »
you can filter it with LPF, but note if you're using relays to switch LPF it can be a problem on so high frequency, because usually mechanic relay is not designed to keep fixed impedance, such applications requires to use RF relay which is expensive
Offline Odysseus
« Reply #2 on: July 07, 2022, 03:18:44 am »
I'd recommend a down conversion architecture over a set of filter banks. For example, use the ADF4351 as a swept LO from 1.03GHz to 1.25GHz to down-convert a fixed-frequency 1GHz sine wave. I'd generate the 1GHz RF with a 2nd PLL and a narrow band-pass filter. Finally clean up the 30-250MHz IF with an appropriate low-pass filter. The worst case mixing product you'll need to worry about will be sitting all the way above 2 GHz.
« Last Edit: July 07, 2022, 03:36:21 am by Odysseus »
« Reply #3 on: July 07, 2022, 06:02:08 am »
Thanks for all the feedback everyone, I appreciate it.
Offline rf-messkopf
  • Mario H.
    • Homepage
« Reply #4 on: July 07, 2022, 01:51:39 pm »
With the ADF4351 this approach has the drawback that the chip would have to run with a significantly lower amount of output division, which means higher phase noise: every division by two will lower the phase noise by about 6 dB, given that the divider does not add any phase noise. The second PLL will also contribute phase noise. If this is critical in the application, I would prefer a harmonic filter bank with the ADF4351. And I would use solid state RF switches rather than relays, as others have already remarked.
There is nothing wrong with a filter bank. But you should carefully asses the amount of LO harmonics you can tolerate with your PA and modulator, and make design choices accordingly. When you are using a class C or E output amplifier, the requirements may be different than with a linear amplifier.
Also, the ADF4351 is rated for output frequencies from 35 MHz to 4.4 GHz. I'm not sure if you will get it to run at 30 MHz when you want to use its output directly without down conversion or further division.
