Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
RF, Microwave, Ham Radio
Antennas for experimentation
« previous
next »
Print
Search
Pages:
Prev
1
2
All
Go Down
Author
Topic: Antennas for experimentation (Read 5241 times)
joeqsmith
Super Contributor
Country:
Re: Antennas for experimentation
Reply #25 on:
November 23, 2022, 07:50:27 pm »
Shown are my latest experimental slip joints for easy tuning. Also shown are the new high tech materials used for spacers.
Logged
How electrically robust is your meter??
https://www.youtube.com/channel/UCsK99WXk9VhcghnAauTBsbg
Solver64 Dropbox
https://www.dropbox.com/scl/fo/j7pypmli6knwnrb2e7ejb/h?dl=0&rlkey=2lnag44rmdkx0f0cgk0x0jfri
tautech
Super Contributor
Country:
Taupaki Technologies Ltd. Siglent Distributor NZ.
Reply #26 on:
November 23, 2022, 08:02:22 pm »
Looking good Joe.
I used 1/8" brazing rod so to be able to fit 2 screw cable joiner inners for the feed points whereas I could've used 1/4" solid copper rod but needed to manufacture adjustable feed points which really wouldn't be a problem on the lathe but as the J Pole was quite small so the the 1/8" brazing rod was quite adequate.
Logged
Avid
Rabid
Hobbyist
Siglent Youtube channel:
https://www.youtube.com/@SiglentVideo/videos
joeqsmith
Super Contributor
Country:
Reply #27 on:
November 23, 2022, 08:45:04 pm »
Maybe some hobby brass tubing and make everything adjustable. Come up with something you like, solder it up. This one can be tuned over a fairly wide range but may not radiate very well.
Logged
Solver64 Dropbox
joeqsmith
Super Contributor
Country:
Reply #28 on:
November 25, 2022, 01:26:02 am »
Second Slim Jim.
Logged
Solver64 Dropbox
joeqsmith
Super Contributor
Country:
Reply #29 on:
November 25, 2022, 04:04:03 am »
The Vivaldi is a bit more directional.
These last two antennas were taken with a 5deg resolution, or 36 elevation and 72 azimuth. Taking 2592 data points by hand would be a nightmare. Added one more zoomed in a bit on the backside.
Last Edit: November 25, 2022, 04:44:53 pm by joeqsmith
Logged
Solver64 Dropbox
nctnico
Grandchuck
joeqsmith
Super Contributor
Country:
Reply #30 on:
November 25, 2022, 10:03:44 pm »
Taking the same Vivaldi and moving to a half meter away from the reference antenna does have an effect on the pattern. Considering that I am testing these in my home lab it's actually closer than I would have expected. Shown from two different viewing angles along with a low res 2D plot of the same setup. Where the SlimJimII was tested a bit over 900MHz, this Vivaldi is being tested at 2.4GHz.
The low cost VNAs don't have very good noise specs and moving it further away could be a problem. My Signal Hound would do a better job making these measurements but it's fun playing with this $120 unit. The LiteVNA's firmware limits measurements to 9.3GHz. I have included data comparing it's noise floor against my old Agilent PNA, both using a 1k IF and again with the PNA set to 100Hz. Also shown is the SA with nothing but a 10dB attenuator attached to it, using the realtime mode with a 2.4GHz center. Note it still picks up interference from my router.
Article using a drone to map the radiation pattern.
https://signalhound.com/news/antenna-measurement-and-characterization-with-uavs/
Logged
Solver64 Dropbox
joeqsmith
Super Contributor
Country:
Reply #31 on:
November 26, 2022, 01:21:10 am »
May not look as pretty, but an effective demo showing the radiation pattern of a dipole.
Walter Lewin Electromagnetic Waves, Solutions to Maxwell's Equations, Polarization
Last Edit: November 26, 2022, 01:29:48 am by joeqsmith
Logged
Solver64 Dropbox
joeqsmith
Super Contributor
Country:
Reply #32 on:
December 01, 2022, 04:05:44 am »
Attempting to use the LiteVNA to sweep an X-band horn.
It's a tradeoff. The performance of the Lite is pretty poor but still, $120.
Logged
Solver64 Dropbox
Thedrunkenflea
Contributor
Country:
Reply #33 on:
December 18, 2022, 03:43:46 pm »
Very interesting stuff - i might have found my next project or two!
Logged
joeqsmith
Super Contributor
Country:
Reply #34 on:
December 18, 2022, 04:38:26 pm »
Looking forward to seeing what you come up with.
Logged
Solver64 Dropbox
Print
Search
Pages:
Prev
1
2
All
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
