Working on a repair project (LeCroy WavePro 7200 timing board) and have two RF packages I've been unable to track down part numbers for - there are quite a few in the path and it's looking like at least one is going to need to be replaced.
Both are 4 pin SMD packages of a familiar shape, the white package is probably ceramic (sounds different when bumped with the tweezers), but the markings are cryptic. _1 for the first black plastic amp (two of them are the first two stages in the path), then S1 for the white ceramic packages of which there are several stages and then a few as a distribution amplifier at the end. The VCO feeding the first stages tops out at 3GHz, and hooked up to the SA, both probing the VCO output, the amplifier stages, and hooked directly to the output of the board I'm seeing 2.43GHz and its second harmonic, so I figure the amps could be good up to about 5GHz (one other transistor I've ID'd near the VCO is rated to 5GHz.
Ideas on what the parts are or a good place to go looking? The markings seem so generic that almost everything comes up in a simple google (especially S1 when searching for RF related stuff...), and I haven't been able to find another reference to the board or trying to repair it.
The black mmic looks like ERA-1, the other one go figure...
They look like MMIC amplifiers from Mini-Circuits which is consistent with the output networks.
Long time ago I also had to decipher one of this 4 legged amps. Eventually it was an old HP, now avago, from the MSA-xxx series. From what I learned I'd recommend you to identify the exact package and narrow from there, there are many, they seem similar, but they are not. You've got the 05 plastic package, the 86...
Eventually it was an old HP, now avago, ...
And now Broadcom. I am waiting for them to put all of the Avago datasheets under a NDA and charge for parts based on application to prevent freeloaders from using mixer diodes in sampling applications.
Haha, I just checked and Broadcom announced this month that they are discontinuing practically everything Avago made. Well, so much for that.
Who else produces microwave schottky mixer diodes?
I think it's likely, though maybe the ERA-1SM variant because of the extra bend in the legs. Looked through the datasheet and the biasing resistor is exactly what they recommend (137 ohms for 9V of biasing), the regulator supplying the bias is set to 9.2V, which should work out to about 3 ohms of DC resistance in the inductor, which seems about right. The bandwidth would also be a match and the VCO itself is also minicircuits.
Still not totally sure about the ceramic package one, the package does seem to be slightly smaller and straight legged, the current minicircuits lineup doesn't list any part numbers that contain "S1" and don't show any of this style ceramic packages... but it's old, I'll have to sift through some previous models.
I think that's it! Looks like I'm not the only one with the google-fu issue, though, without the "MMIC" it seems tough to find. (same story here
https://www.eevblog.com/forum/testgear/teardown-repair-analysis-of-an-agilent-e4443a-3hz-6-7ghz-spectrum-analyzer/ )
Anyways, while the biasing resistor on the first one in the chain is too high for the recommendation on the datasheet, the remainder of the ones later in the path are using 105 ohm bias resistors, which is right in line with what I'd expect for 9V. Odd though, my last repair also involved replacing some Sirenza amplifier parts.... I guess they're popular, at least.
Well that's cruddy.
Answer: Skyworks (some fairly nice ones relative to the mainstream / low cost / consumer end of nice as opposed to the super exotic pure unobtainium kind of nice).
Also I think M/A Com which IIRC is now Analog Devices.
You might check CEL / Fujitsu / Sony / Panasonic too or whatever is left of them. They have/had some RF stuff, not sure about vanilla diodes. Hmm NXP / Infineon make a lot of consumer small signal transistors up at high frequencies, though I don't remember diodes being prominent in their line-ups, seems odd.
I found no lack of alternatives but none as good as the Avago parts. Unfortunately using them means starting over with qualifications.
I would have hoped they would have just let someone else buy out the Avago products they're not interested in, it sounds like it may well put a damper on the availability of certain segments of products. It'd be nice if say DIODES or NXP or someone would pick up more of the higher performance but mainstream RF stuff.
I wondered if Broadcom bought Avago to compromise a competitor. Now I think that was the case.
Well that's cruddy.
I also see a pattern here. Specifically, that components are discontinued which did sell and which were not problematic to produce, so that they should be kept in the portfolio if there wasn't a hidden agenda.
If nobody is selling the basic components to make up new circuitry, all innovation outside of the semiconductor manufacturers is stifled. Combined with the fact that they handle their product lines like if there is no responsibility of any sort, one might think that a lot of totally unneccessary redesigns occur.
Actually, Avago bought Broadcom. They changed their name from Avago to Broadcom Limited. They did not have competing product lines.
Who bought who doesn't actually matter and I wasn't talking about them competing with themselves. If they have other competitors with Broadcom who were relying on Avago's products for support, then it makes sense to discontinue those Avago products. Usually I see it where one of two competitors buys a company that the other is relying on either directly or through their customers encouraging their customers to switch.
Anyway, it was not as much of a problem as I suspected it would be and I now have a handful of substitutes for everything I was using from Avago. Broadcom is not a problem because I hate their products.
