Hi all,
I need to test an amp at 10Ghz and rated for 20W output power.
I am torn between deciding to go whether for a Attenuator or Termination (dummy load : 50ohms) .
The load I was looking at is rated for DC-20GHz and 50W, while the attenuator is rated for DC-20GHz and 50W and has 50dB attenuation......both are around the same price.
Am I right in assuming that the attenuator would be a better choice since I can hook it up to the amp and then monitor the output of the attenuator on a spectrum analyzer?
If I use a load then I have no method of monitoring the power......any limitations in using a attenuator for this use case?
Even if I leave the attenuator output end open, it should act like a reasonable dummy load with -100dB reflecting back to the amp?
