First impressions:
I haven't put together the MLA-30 yet but I did have a chance to play with the RTL-SDRv3 dongle and stuff that came with it (accessories package which includes some antennae and stuff):
I made myself a persistent USB key of skywavelinux 4.0 and after trying it on a few different computers I can tell you that I was not getting the best experience. Half of the apps crashed or didn't load or froze. For example, while Gqrx worked, CubicSDR didn't and LinHPSDR just stayed on the initialization dialog forever. It could be that skywavelinux doesn't like running on a USB key.
Add to that the i3 Window Manager (which I am starting to like) but the key-mappings were not standard and overall the user-experience with the many crashing or half-working apps was not instilling much pleasure from booting up the key.
So I decided to just install everything into my existing linux machine (Ubuntu Studio Bionic) and things went much better. I installed the RTL-SDR drivers, Gqrx (gprx-sdr) directly through sudo apt install commands, CubicSDR using an AppImage, and modified the conf files to blacklist the other drivers so that the dongle would be properly recognized when plugged in. All the instructions basically found on RTL-SDR.COM Quick Start Guide and this tutorial:
https://ranous.files.wordpress.com/2018/02/rtl-sdr4linux_quickstartv2-18.pdfI had previously already installed fldigi and WSJT-X on same machine so now there is a Ham RADIO applications menu now showing up with all this stuff in it (somehow automatically ended up in there with all these apps going to that submenu).
The only thing that didn't work from the tutorial is getting the Dump1090. I cloned the git suggested and followed the make instructions but there were warnings/errors that thwarted success. Even turning off the Werror flags in the Makefile didn't get me any further and I didn't have time to start debugging the code. So I may try to find another Dump1090 fork to see if I have any better luck.
One other HARDWARE ISSUE that I found, which I'm not sure about... When I screw the whip antenna SMA male on to the RTL-SDR dongle SMA female, if I screw it on too much (too deep or tight) I lose reception, as if it is not plugged in at all. I tried everything from wiggling the cable, putting my finger on it, squeezing, etc. The same effect is reproducible. Basically... with no antenna attached there is basically just static. Once I thread on the antenna SMA maybe a few turns I get reception, but if I go past a certain point (SMA still easy to thread) I lose reception again....even until it finally is on tight, no reception.
Is this something to do with the SMA hardware design and improper electrical contacts on the male/female? I haven't tried any other cables or antennas but this is my first experience out of the box with the whip antenna it comes with. Once it is attached properly (a few threads in but not tight) I get amazing FM stereo reception and can even see RDS music/station info. I get so-so AM reception (I use the direct sampling to get down under 24Mhz) but can definitely pick it up. And I also find some of the stronger (mostly religious) shortwave stations in the 3000-8000 Khz range on the whip.
So far all these tests were in the kitchen. I'm looking forward to going upstairs and trying the long-wire antenna and higher elevation, as well as MLA-30 loop to see what differences I get.
A lot of "tongue at the right angle" it seems but slowly getting there!
