Hi there, folks, just stumbled upon an interesting antenna design described here
http://www.crosscountrywireless.net/cardioid_loop_antenna.htmnow, the idea isn't new, since it's basically the same "loop and whip" idea used for radio direction finding, what's interesting is that in this case the loop itself acts as both the loop and the whip; being curious, while I didn't try it yet (will do, probably next week if time permits), I decided to put together a NEC model and run some simulations to see what to expect from the antenna and if I could somewhat improve it, the resulting (optimized) model is this one
CM File: loopant.nec
CM optimized vertical cardioid loop antenna
CM impedance arount 450 Ohm from 0.1 to 30 MHz
CM feed with a 9:1 BalUn
CE
' symbols
SY frq=7.100 ' test frequency
SY rad=0.5 ' loop radius
SY hgh=1.20 ' height from ground
SY ray=0.00125 ' wire radius
SY res=510 ' resistor
SY seg=3 ' segmentation
SY se2=11 ' ground wire segmentation
' loop geometry
GW 1 seg 0 rad*sin(0) hgh+rad*cos(0) 0 rad*sin(10) hgh+rad*cos(10) ray
GW 2 seg 0 rad*sin(10) hgh+rad*cos(10) 0 rad*sin(20) hgh+rad*cos(20) ray
GW 3 seg 0 rad*sin(20) hgh+rad*cos(20) 0 rad*sin(30) hgh+rad*cos(30) ray
GW 4 seg 0 rad*sin(30) hgh+rad*cos(30) 0 rad*sin(40) hgh+rad*cos(40) ray
GW 5 seg 0 rad*sin(40) hgh+rad*cos(40) 0 rad*sin(50) hgh+rad*cos(50) ray
GW 6 seg 0 rad*sin(50) hgh+rad*cos(50) 0 rad*sin(60) hgh+rad*cos(60) ray
GW 7 seg 0 rad*sin(60) hgh+rad*cos(60) 0 rad*sin(70) hgh+rad*cos(70) ray
GW 8 seg 0 rad*sin(70) hgh+rad*cos(70) 0 rad*sin(80) hgh+rad*cos(80) ray
GW 9 seg 0 rad*sin(80) hgh+rad*cos(80) 0 rad*sin(90) hgh+rad*cos(90) ray
GW 10 seg 0 rad*sin(90) hgh+rad*cos(90) 0 rad*sin(100) hgh+rad*cos(100) ray
GW 11 seg 0 rad*sin(100) hgh+rad*cos(100) 0 rad*sin(110) hgh+rad*cos(110) ray
GW 12 seg 0 rad*sin(110) hgh+rad*cos(110) 0 rad*sin(120) hgh+rad*cos(120) ray
GW 13 seg 0 rad*sin(120) hgh+rad*cos(120) 0 rad*sin(130) hgh+rad*cos(130) ray
GW 14 seg 0 rad*sin(130) hgh+rad*cos(130) 0 rad*sin(140) hgh+rad*cos(140) ray
GW 15 seg 0 rad*sin(140) hgh+rad*cos(140) 0 rad*sin(150) hgh+rad*cos(150) ray
GW 16 seg 0 rad*sin(150) hgh+rad*cos(150) 0 rad*sin(160) hgh+rad*cos(160) ray
GW 17 seg 0 rad*sin(160) hgh+rad*cos(160) 0 rad*sin(170) hgh+rad*cos(170) ray
GW 18 seg 0 rad*sin(170) hgh+rad*cos(170) 0 rad*sin(180) hgh+rad*cos(180) ray
GW 19 seg 0 rad*sin(180) hgh+rad*cos(180) 0 rad*sin(190) hgh+rad*cos(190) ray
GW 20 seg 0 rad*sin(190) hgh+rad*cos(190) 0 rad*sin(200) hgh+rad*cos(200) ray
GW 21 seg 0 rad*sin(200) hgh+rad*cos(200) 0 rad*sin(210) hgh+rad*cos(210) ray
GW 22 seg 0 rad*sin(210) hgh+rad*cos(210) 0 rad*sin(220) hgh+rad*cos(220) ray
GW 23 seg 0 rad*sin(220) hgh+rad*cos(220) 0 rad*sin(230) hgh+rad*cos(230) ray
GW 24 seg 0 rad*sin(230) hgh+rad*cos(230) 0 rad*sin(240) hgh+rad*cos(240) ray
GW 25 seg 0 rad*sin(240) hgh+rad*cos(240) 0 rad*sin(250) hgh+rad*cos(250) ray
GW 26 seg 0 rad*sin(250) hgh+rad*cos(250) 0 rad*sin(260) hgh+rad*cos(260) ray
GW 27 seg 0 rad*sin(260) hgh+rad*cos(260) 0 rad*sin(270) hgh+rad*cos(270) ray
GW 28 seg 0 rad*sin(270) hgh+rad*cos(270) 0 rad*sin(280) hgh+rad*cos(280) ray
GW 29 seg 0 rad*sin(280) hgh+rad*cos(280) 0 rad*sin(290) hgh+rad*cos(290) ray
GW 30 seg 0 rad*sin(290) hgh+rad*cos(290) 0 rad*sin(300) hgh+rad*cos(300) ray
GW 31 seg 0 rad*sin(300) hgh+rad*cos(300) 0 rad*sin(310) hgh+rad*cos(310) ray
GW 32 seg 0 rad*sin(310) hgh+rad*cos(310) 0 rad*sin(320) hgh+rad*cos(320) ray
GW 33 seg 0 rad*sin(320) hgh+rad*cos(320) 0 rad*sin(330) hgh+rad*cos(330) ray
GW 34 seg 0 rad*sin(330) hgh+rad*cos(330) 0 rad*sin(340) hgh+rad*cos(340) ray
GW 35 seg 0 rad*sin(340) hgh+rad*cos(340) 0 rad*sin(350) hgh+rad*cos(350) ray
GW 36 seg 0 rad*sin(350) hgh+rad*cos(350) 0 rad*sin(360) hgh+rad*cos(360) ray
' ground connection wire
GW 99 se2 0 rad*sin(170) hgh+rad*cos(170) 0 rad*sin(170) 0 ray
' end of geometry
GE 1
' ground parameters
GN 2 0 0 0 13 0.005
LD 7 0 0 0 2.1 ray ' insulation
LD 5 0 0 0 58000000 ' copper
LD 0 1 1 1 res 0 0 ' resistor
' feeding
EK
EX 0 18 seg 0 1.0 0.0
' frequency
FR 0 1 0 0 frq 1
' end of model
EN
the model describes a circular loop antenna with a diameter of 1 meter, placed at 1.20 meters from ground and with a 510 Ohm resistor at the top; it's important to notice that raising the antenna (to e.g. 2 meters) would cause the directional pattern to disappear at frequencies above 8 MHz (the pattern would become omnidirectional); also, the choice of the 510 Ohm resistor gives an impedance around 450 Ohm at the feedpoint which is easily matched using a 9:1 BalUn so the antenna could then be connected to whatever preamplifier or other circuit; the structure of the antenna is as follows
basically there's a resistor at the top which splits the loop in two halves, one of those is connected to ground through a run of wire, the resulting antenna offers a radiation pattern like the following one
as you see, from 0.5MHz up to 30MHz the antenna pattern is directional with a pretty low takeoff angle, also, as I wrote, the 510 Ohm resistor allows to find a good match offering an impedance of around 450 Ohm at the antenna feedpoint, the result is the following SWR curve
as you see, the mismatch is minimal, so feeding the antenna through a 9:1 BalUn will allow to directly connect it to whatever standard preamplifier; again, didn't (yet) find the time to build it, but will do as soon as possible, I was also considering the idea of recovering my MLA-30 from the basement and trying to transform it into a "cardioid loop", that one should be an interesting experiment too, although in such a case I'll need to find a value for the resistor which will offer a decent match to the MLA preamp unit
