Is there a solution to put an 2.4G antenna on top of a solid ground plane? So far I've been designing with 2450AT42E0100, which is globally in short supply, so I need another solution.
I know Taoglas has their SWLP2450 series ceramic antenna blocks, but I can't accept their sizes either. Something like 2mm*5mm is good, maybe I can stretch to 2.5mm*8mm, but that's it.
I'm experimenting on common antennas+RF absorbing sheet on bottom side, but as I'm waiting for parts, it will be days before I can confirm the results.
