Author Topic: fridge magnet iron loaded flexible sheeting?  (Read 1882 times)
Offline cdevTopic starter
« on: October 21, 2021, 08:07:25 pm »
Can it be used as a poor mans RF absorbent material?
I am talking about the material that merchants use to make printable fridge magnets (at least here they do) that they give you. Its cuttable and may even stick to some (steel) metal cases.
I dont know, it just seems as if it may be useful to cut resonances and cheap.
Offline coppercone2
Re: fridge magnet iron loaded flexible sheeting?
« Reply #1 on: October 21, 2021, 09:26:02 pm »
they also sell tape in the hardware store like that, itsvery weak but good enough for a paper
Offline 3roomlab
« Reply #2 on: October 22, 2021, 01:23:34 am »
i have considered the same as you. i have not tried. but it seems very plausible. i tried some random femm just for magnetics and it looks ok to my untrained eye. i think the soft sheet workability is a plus as opposed to sheet metal working in certain situations. i saw online stores that sell it in large per meter rolls 1mm to 3mm
Offline coppercone2
« Reply #3 on: October 23, 2021, 04:15:49 am »
I think I have a roll of that tape, if you can design a experiment I can try it up to 300Mhz
putting a sheet between a signal and receiver coil (like NFC coils?) might work as a test?
I thought about it because of ferrite rod antennas, big ones, where you have the option of using ribbon cable as a shield, but I still am not fully sure how ferrite material around the coil acts like, so its possible to make a rib-cage of magnetic tape to experiment with ferrite rod antenna characteristics, if it has a different from solid conductor metal strip material, or to find out if sticking it on top of strip material might do something desirable
Something tells me a proper test is laying it on the inside of a horn antenna or TEM cell or something (waveguide?) maybe, to see how much signal gets out? My horns all have polarization layers or optics on them though
« Last Edit: October 23, 2021, 04:20:00 am by coppercone2 »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: October 23, 2021, 07:47:18 am »
I doubt it.  The material is magnetically hard, it should have little permeability.  Likely losses are dominated by dielectric (what's the carrier, rubber? PVC? And the ferrite should still have (di)electric losses).
Seven Transistor Labs, LLC
Offline coppercone2
« Reply #5 on: October 23, 2021, 05:29:37 pm »
how about just rolling it up  into a swiss roll and then winding wire around it to measure it like a normal rod inductor of the same size with a known core (film canister big ones) from a good manufacturer. it should be geometrically close to a cylinder. Or winding it into a swiss roll and sticking a insulated wire through the middle like its a big ass ferrite bead and measuring that in a RLC meter or impedance analyzer. That should give you power performance and RF performance, after all, it is some kind of ferrite bead I think, since its just a strait pass of wire through it, it should be fairly RF friendlier.
Can those parameters be used to select a screening/antireflection material?
Otherwise how about the normal test, two horns aimed at each other through a reflector, then coat the reflector with the material (its just a 45 degree plate) to see how much the signal propagation changes.
Building your own inductor core at custom sizes by wrapping tape together like a wasp hive is interesting also. Particularly if its wrapped with epoxy (possibly thermoset) so you can get a good quality part afterwards. I guess it would be the closest thing you can get to nanocrystaline tape from the HW store.
« Last Edit: October 23, 2021, 05:39:35 pm by coppercone2 »
« Reply #6 on: October 23, 2021, 05:42:54 pm »
I was thinking about damping resonances in instruments where they become problematic. For example, in the nanoVNA2 discussion threads it emerged that using a metal case for a nanovna2 introduced resonances between 3-4.5 GHz,  that were caused by the presence and size of the case. Without a metal case, no problem. The metal cased units would likely benefit greatly from a damper, but the costs of these materials is significant.
 I have had similar problems with low noise amplifiers.
« Last Edit: October 23, 2021, 05:52:33 pm by cdev »
Offline Wallace Gasiewicz
« Reply #7 on: November 01, 2021, 09:23:59 am »
Someone had a problem with a 10 Meter mobile amp oscillating. Multiple attempts to assure the integrity of all the coax, antenna, grounding, power cables  and connections did not help
He wrapped it in sticky padded aluminum tape from the hardware store, that solved the problem We were surprised at the success of this endeavour but did see it work. The tape itself was not grounded, Apparently it changed the resonance of the case. The foam padding created a gap between the metal cans and the outside aluminum.
Again,we did not think it would work and were surprised at the result.
