Hi!
Im trying to design a very basic colpitts, ~40 Mhz oscillator ( or above), the problem is that i can't make a realizable air core inductor (i can't make a inductor with less than 1 loop) or maybe i choose the wrong architecture.
Do you have any suggestion for me?
Some hints:
- your capacitive divider is wrong. The upper cap must be larger (3-5 times) than the lower.
- your LC is wrong, too. L should be a lot larger, and C accordingly smaller. Then making a reasonable coil is a cakewalk.
- Try a Clapp (series resonator) instead of a Colpitts (parallel).
- Buy a good book about oscillator design theory. IMHO, a Colpitts or Clapp at 40MHz is absolutely no rocket science.
ARRL has some info, or Rohde, Oscillator Design, ...
- If you want low output noise, decouple thru the resonator. You will need an isolation stage anyway.
- The transistor fT should at least be 10x the oscillation frequency. Not true for your 2N2222A.
Have fun experimenting
Wolfgang DL1DWG
