Author Topic: HP8753C VNA Sampler Teardown & Reverse Engineering  (Read 12157 times)
Offline JoeyDengTopic starter
Re: HP8753C VNA Sampler Teardown & Reverse Engineering
« Reply #50 on: May 03, 2025, 03:23:21 pm »
all the things works fine :phew:
« Reply #51 on: May 03, 2025, 03:25:31 pm »
But my spectrum is dead :pdead, Next plan is to make a spectrum analyzer with the components in this anritsu ms710.
« Reply #52 on: May 03, 2025, 03:27:17 pm »
the noise figure of source is in spec and acceptabel😆
« Reply #53 on: May 03, 2025, 04:09:32 pm »
After spending a longgg time washing this sh!t spectrum analyzer which with a large amount of juicy battery.  :rant: I just want to gave up, almost all the logical parts and AFE are dead. The IF generator is dead and the front att and sw also has get damp…  :scared:  :-BROKE
Offline EggertEnjoyer123
« Reply #54 on: May 03, 2025, 06:28:21 pm »
Are you using the KHD-23 connectors?
Have you simulated the transition yet for those yet?
« Reply #55 on: May 03, 2025, 06:43:43 pm »
I use sma-kcd47. And I’ve done the simulation in ads with a paltry number of parameters, I bought a lot of magnetic ring, but none of the seller provides the exact parameter for simulation.  :-// and also I’m  really curious abt how HP make their directional coupler have that high directivity. So I did some research on “Joel P. Dunsmore "Dual directional bridge and balun used as reflectometer test set," US Pat. Nº 4 962 359, Sept.10, 1990.” But I haven’t got any inspiration yet  |O
