Ok here is the deal I found the signal buy going through the FCC database and drove by the facility where its coming from. In order to get any directonal signal loss using this antenna
https://www.tessco.com/products/displayProductInfo.do?sku=42395 I had to get my LNA out of the chain and set my dongles gain down to 2.7! This is strange considering the broadcast is at least 5 miles away and is only 9 watts ERP. Here is the stations
FCC listing 450.98mhz it says it is used for Broadcast Auxiliary Remote Pickup, I couldn't find a definition for this exact term online, but after doing some research I think the signal is a digital route of 93.7FM which is about 30 miles away and is 95.5FM in my town. Here is the signal, these were recorded my yagi pointed at station and AGC turned on, even 3.7db of gain was overloading and causing aliasing.
This is a recording of just the IF or selected bandwidth, it works fine in audio programs and SDR# but im not sure if it work in other SDR software. It is also not as clear as the the full IQ file as far as the waterfall, it takes a lot of playing with contrast, offset, and range in SDR# to get it reasonable. I uploaded this because it is a 10mb file with 40 seconds worth of data.
https://dl.dropboxusercontent.com/u/27653605/IFonly.wavThis is a minute and a half file a 80mb it is recorded regular and is very clear in SDR#, should work in all SDR programs. I recorded it using .25msps i figured the less bandwidth recorded the smaller the file.
https://dl.dropboxusercontent.com/u/27653605/FullIQdot25msps.wavSo this is my thing, its why I love SDR I want to find signals and demodulate/unencrypt them if possible. My problem is if is not a cw or analog voice signal, and isn't in the SDR signal wiki I dont know how to analyze the signal of figure out its modulation. Sometimes using Audacity works well but thats really only for low speed binary stuff FSK, OOK, etc. So knowing the info I posed above about the station would you all agree its an FM station being transverted and encoded to a digital stream to route from town to town. If thats it where would I start trying to figure out its modulation scheme etc...?? Also why does the standard 3 inch rtl sdr antenna pick this signal up so strong all over a 20 mile radius, and it breaks through my yagis back reflectors when the gain is to high. Admittedly I am higher than the antenna and my yagi is direct line of site, but I receive this thing on the junk antenna all over and im not in line of site!!! How??!! They have an antenna design I have NEVER seen but its still only a 1 watt signal?
