Author Topic: Looking at ham radio?  (Read 9116 times)
Offline janoc
Re: Looking at ham radio?
« Reply #25 on: October 27, 2017, 08:42:52 pm »
CB radio seems like a great suggestion. I'll also tell him how to make an inverted vee so he don't have to spend a lot of money. Big hiway isn't too far away either, so he can get practice with the truckers.  :popcorn:
CB can be hit and miss - it's popular in some areas and not in others. Eg in Australia most truckie activity is UHF not 27 MHz.
If go the CB route you will need a vertically polarised antenna to talk to mobile stations.
Either a vertical dipole or ground plane made of wire would be fine.
An inverted vee won't be so good.
Um, a vertically polarized antenna on HF is a "horizontally polarized" piece of wire that you hang down from the nearest tree ... Put a good balun, some wire for a counterpoise and an antenna tuner capable of handling a long wire antenna in your kit and no problems. All of that can be had or made quite cheaply.
And anyhow, when you are working CB you are working short distance, perhaps 10-50 kilometers (depending on terrain). So even a non-ideal antenna will work. You are probably not going to be dx-ing on it but it will be good enough to call for help. Otherwise buy a collapsible whip like truckers use.
Offline Lord of nothing
  • Country: at
« Reply #26 on: October 29, 2017, 12:17:33 pm »
the main problem are powerline on <30mhz. If someone near the receiver (~500m) use its impossible to use CB.  :palm:
Made in Japan, destroyed in Sulz im Wienerwald.
Offline janoc
« Reply #27 on: October 29, 2017, 02:01:20 pm »
If the OP lives in a BPL area, then anything HF wouldn't work, not only CB. BPL uses anywhere from 2 to 80MHz ...
However, that is then a matter for an FCC complaint because of unlawful interference.
There are some ongoing efforts on this front, both in Europe and US, because HAM radio frequencies are protected. Unlike CB, HAMs have exclusive use on some of the HF bands and HAM radio is defined as a separate radio communication service by ITU - on the same footing as e.g. radio and TV broadcast, air, marine communications, etc.
Fortunately these trials are not very widespread because the technology is, frankly, crap. DSL or cable both perform better and are widely available, without any of the issues BPL has.
And if someone is using the powerlines "boxes" to connect e.g. TV to their broadband box (what they call "CPL" here in France - saves an ethernet cable between the two) and it causes interference, then that is a matter of installing a filter on their side. Also a complaint to the regulatory authorities will do wonders, both because of the CE EMC compliance requirements of these gadgets and unlawful interference. These things are common here in France, in fact I have two myself, and usually don't cause trouble. There is so much noise and hash on the bands in the cities already that these gizmos are not a problem if they function correctly.
« Last Edit: October 29, 2017, 06:58:58 pm by janoc »
Offline cdev
« Reply #28 on: October 29, 2017, 03:57:22 pm »
Even in emergencies, no, especially in emergencies, especially in the US, we now should understand that everything they do is likely constrained by the ideology which they are trying to sell the entire world on. In many cases, the world may have already signed on to this ideology but not realize it. So the US has to "show them the way".  This is a way that's designed to maximize economic advantage (profits) in every situation. Thas whats seen as good now.
Period.
In every case where a decision is made, that's the decision that gets made. That's really changed everything. Its the missing link to understanding policy now. Understand that and everything falls into place.  So all sorts of what seem like inexplicable, bad decisions are being made, but they all make sese if you understand this. This is being done because the alternative, the way this were before would lead to slippery slopes where profits would have tob be abandoned in favor of non-profitable policies. Because of economic shifts in the world eventually that would lead to changes they feel pose an existential threat to corporations. So they have made that impossible behind the scenes by international agreements between powers without any discussion in the media at all.. without telling almost anybody. Because almost everybody who hears about them disagrees with it. Irregardless of their feelings beforehand. Because they fly in the face of the most basic common sense.
I will try to keep this short.
Have you ever heard of the concept of "minimal trade restrictiveness"? Its part of something called competition policy?
I don't want to derail the thread so I will make this explanation very short. Of the various ways to get broadband into an "underserved community" whatever policy a government that subscribes to this ideology undertakes -has to interfere as little as is possible with international trade and investments. Like the investments that foreign firms might make in US telecommunications infrastructure, or vice versa. (its reciprocal- that's the key to understanding why its being done so aggressively)
For example, powerline networking may be crap but that's actually good if you want to up-sell *better* more profitable services to the people who can afford better.
Most importantly, whatever they do "regulation" can't exceed the most minimally trade restrictive means possible to accomplish the goal. It cannot make investors lose the value of their investments in a country. If it does they may have to be paid that money, the future expected lost profits they expect lose, in advance, to free the country from that particular policy constraint. So they can carve it out forever in writing. They likely can't do anything that could be seen as causing "crowd out"- that broadly means anything where some government activity might inadvertently reduce the profits expected by some investor.
Throwing a wrench into their 'legitimate expectations'.
A trade agreement is like a permanent irrevocable (after three years or similar) contract where a government agrees to put the international investors interests first ahead of all others, permanently, with only the very narrowest exceptions allowed for certain conditions. Also, only deregulation is allowed, re-regulation is prohibited except under the very narrowest of exceptions (which are admitted to almost never apply)
Such as situations that threaten human lives, etc. as long as that goal is not inconsistent with the goal of the agreements. The deals come first.
 It might be argued successfully that internet access is a necessity of life (although I doubt if that argument would succeed, frankly, when so many other similar arguments for far more essential things have not.) , but if it was allowed "to help communities", it must be "minimally trade restrictive" which is defined legally- its a legal standard. Another standard is "not more burdensome than necessary to ensure the quality of the service". So foreign firms must be allowed to assist in the effort, as they might be cheaper.
When government procurement/subsidies are involved, A community cannot monopolize the jobs when a foreign firm might be able to come in and accomplish the goal for less using their workforce.  Local community groups helping might be seen in a negative light if they prevented the use of large numbers of foreign workers from countries who might have signed on to trade agreements knowing hat they could provide those kinds of services for less money than domestic firms would. And they could.  That knowledge of the eventual payoff in jobs may have kept them in the talks for 20 years of negotiations. An entire generation of people may have pursued certain courses of studies in college and grad school knowing that these agreements would attempt to funnel certain kinds of jobs to them.  At least these are the arguments we can expect to hear made if changes are proposed to these deals.. now after 20 years.
When do they kick in? When governments are involved. If a service is completely private and commercial wit no government involvement at all, or when its completely noncommercial and free everywhere in a country, supplied by the government with no competition, like healthcare in Canada, (but not drugs or some kinds of care) they don't apply.
But everything that is in between those two extremes, they do.
Which is almost everything, they do.
When a circumstance meets those conditions, whatever they do, if it is at all possible to minimize its impact it must be designed to be "minimally trade restrictive"  or they may be sued in special courts. (If a country can claim to be injured, say by having the opportunities they have long expected taken away from them)
Tendering and procurement must follow a certain framework such as to ensure that all WTO members get an opportunity to bid on the provision of the service.
An index is being set up, the  "Services Trade Restrictiveness Index" to offer governments, which oftentimes don't understand these binding agreements, (because they are relatively new, having been set up in the 90s but delayed because of ongoing negotiations)  guidance in what the "best practices" would be for them to stay out of trouble in a host of different areas.
Hams may need to make the case that somehow protecting their activities generates more economic advantage, but that may open a can of worms because those same services might be seen as offering poor countries opportunities for economic development. So, discouraging hams by encouraging devices that made ham bands unbearably noisy, might be framed as a necessary evil, and claimed to help the cause of economic development for countries that might hope to replace them in provision of emergency services. Which may become more and more dangerous and costly because of chemical spills, etc. as weather becomes less predictable.
I think the emergency aspect is an important one, but it may actually be seen as decreasing the "legitimate" profit-making opportunities of commercial firms under the circumstances (after all, in emergencies, companies have a right to charge more - this is another change-)
for hams to help communities in emergencies because they don't charge money, if otherwise government might be forced to seek the (expensive) services of commercial firms.
Not charging money, i.e. giving away a service somebody might charge for, is framed as a sort of theft.
That might be framed as a loss. I don't know.  But from what I know, its entirely possible, even probable, I think.
This is what I mean by it not making sense to most of us.
« Last Edit: October 29, 2017, 05:49:12 pm by cdev »
Offline janoc
« Reply #29 on: October 29, 2017, 07:05:31 pm »
I don't want to get into politics and, frankly, can't make much sense out of your rant, cdev.
The fact is that BPL causes interference on a large scale. May not be a problem in the country of the size of the US but if a government of one country in the EU tried to authorize this on a large scale, the neighbors would eat them alive - the noise and interference propagates huge distances on these frequencies, especially if the signals are carried by wires on power poles and not underground (aka superb long wire antennas).
The argument about developing "poor countries" trumping the HAM interests flies out of the window, given the deployments in Sweden, Austria, France, Germany, etc. - hardly "poor" countries. And there are not only HAMs (that most lobbyists and many regulators don't give a flying f..k about) on these frequencies ...
So it is not so simple.
The following users thanked this post: Long_Wave
Offline cdev
« Reply #30 on: October 29, 2017, 07:52:22 pm »
I was just trying to explain that a well intentioned and true argument that ham activities needed to be preserved because of services rendered during emergencies might run into unexpected problems for the reasons I described.
I really cant explain the situation without getting into politics.
Hams really need to USE their spectrum because otherwise it could be sold off to the highest bidder, soon.  Because people helping one another can be framed as undermining policy goals to trade market access to other entities. kind of like the agreements that towns in the Sydney area had to agree to to not expand public transit because of privatized highways. An extremely unwise trend, but its very real.
Spectrum needs to be used to be kept.. It may be extremely important to keep it because in the future, when things happen, for example, extreme weather events, help may not be there from outside unless communities can pay money they likely won't have.
Quietly, everything has been changed. In a really bad way.
Okay, thats all I can say here.
http://www.bilaterals.org/?emergency-services-turn-life
https://www.nytimes.com/2016/06/26/business/dealbook/when-you-dial-911-and-wall-street-answers.html
« Last Edit: October 29, 2017, 08:50:44 pm by cdev »
Offline cdev
« Reply #31 on: October 29, 2017, 08:29:06 pm »
I have two questions.. Can the IC7300 band scope display to a monitor (for higher resolution) and also how is the IC7300 receiver in noisy band conditions?
Also, does the IC7300 have an antenna tuner integral to the rig?
My 2 cents...
I have owned the IC-718, IC-7200, and IC-7300.
The 718 receiver sucks,  The AGC is horrible.
The 7200 is great.  No filters to buy. Good performance
The 7300 is wonderful.  That is what I am currently using.  Well worth the money.
After the 7300, my second choice would be the 7200.  Very rugged for portable operation.  You can find them used for a good price.
The 7300 touch screen and band scope will spoil you.
Randy K5HJ
Offline dr.diesel
« Reply #32 on: October 29, 2017, 08:36:14 pm »
The 7300 does not support an external monitor, and yes it has a built in antenna tuner.
Noisy band performance is "normal" IMO, no worse or better than similar rigs.
Offline cdev
« Reply #33 on: October 29, 2017, 08:55:05 pm »
I am certain it has a good noise blanker..
have you ever used it with a magnetic loop? I am asking because of a loop's preselection on receive.
(Many people are stunned by how quiet loops are on receive, BTW.)
At some point when I get my ham ticket, I need to buy a rig and I am trying to figure out whether I should buy a conventional rig thats hamlib compatible and use it with an SDR - which works pretty well.. or whether I should go SDR all the way..  with a couple of options..
A 7300 is kind of over my price range but I could see myself getting one as a second rig in a year or two if I find myself liking it a lot.
Ive gotten kind of spoiled using an SDR receiver but my QTH is really noisy and I have always struggled with it. the worst noise comes and goes. Sometimes its there, sometimes it isnt.
I guess I'll never know if I can somehow get through that QRM until I try it!
« Last Edit: October 29, 2017, 08:58:44 pm by cdev »
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #34 on: October 30, 2017, 12:54:05 am »
My experience is that the 7300 tuner is good for matching SLIGHTLY mismatched loads (VSWR < 3.0), but if you want to use, say, a 20 meter dipole on 40 meters, you're going to need an external tuner.
And I would agree that receive performance is about average for similar rigs (i.e. similar price).  The 7300 runs rings around my other HF rigs (IC718, FT-857) in terms of receive performance.  I have an Elecraft KX2 that actually has very similar receive performance, but that's a whole different story :)
Honestly, if you have the money, I do think the 7300 is the best deal out there (with the exception of the mediocre tuner ....)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Free online test and measurement fundamentals courses from Rohde & Schwarz:  https://tinyurl.com/mv7a4vb6
Offline cdev
« Reply #35 on: October 30, 2017, 01:03:28 am »
My experience with my other SDRs is that a physical (LC) antenna tuner or at least a switchable balun to do rudimentary matching is necessary to get the most out of all my SDRs (on receive)
I think its because of decoupling the antenna and earth ground from the power system ground.
Offline FlyingHacker
  • You're Doing it Wrong
« Reply #36 on: November 15, 2017, 04:44:56 am »
The 7300 most certainly,CAN be used wth an external monitor on a computer. You connect it via USB, then you can use N1MM software to get a realtime full screen waterfall (that even shows callsign s of DX spots).
You can also use Icom's remote software, though with the Icom software the width of the waterfall is restricted to a fairly small width (I think it is the same number of pixels on the built in screen). The height (Y axis) can go as high as your monitor, though.
The 7300 is above average is dealing with weak signals. Don't expect miracles, but it works better than most rigs if you know how to use it (receive bandpass, filter cutoff, Nose reduction settings, twin passband tuning, notch filter-- especially use of the manual, notch, etc.).
The built in antenna tuner supports SWR up to 3:1
It's a nice rig, and definitely the best in its price range.
« Last Edit: November 15, 2017, 04:43:01 pm by FlyingHacker »
--73
« Reply #37 on: November 15, 2017, 04:51:47 am »
A phasing noise canceller, like the MFJ-1026 can do wonders with knocking down individual noise sources, for ham radio, or SWL.
But take the time to go through your house and turn everything off to identify source of noise. Then replace them, or choke them with ferrite torroids or beads. You really can make a huge difference in your noise level doing this. I found my cable modem was the source of noise on almost all bands. It was being radiated back through the AC and through the incoming coax (as common mode on the outer shield). Choking both of those wires with seventeen turns through a mix 31 torroids solved it (one torroid on the AC line, one on the coax).
« Last Edit: December 04, 2017, 11:59:05 pm by FlyingHacker »
--73
Offline denverpilot
« Reply #38 on: November 15, 2017, 07:06:09 am »
... use N1NM software to get a realtime full screen waterfall (that even shows callsign s of DX spots).
Did you mean N1MM?
Offline cdev
« Reply #39 on: November 15, 2017, 04:31:38 pm »
The IC7300 is out of my price range for now.
But this is very very good advice for any SDR user. I've used ferrite cores extensively on all our electronics and it's helped an absolutely huge amount with my reception on HF.
But I haven't bought and used large toroid cores like you have - despite knowing that is definitely the best thing to do this for HF.
Instead Ive mostly used smaller clip on cores of various sizes in quantity.
Our cable modem and router setup definitely could use some further RFI suppression measures.
I wish I could find a source of suitable magnetics in bulk, that's cheaper.
« Reply #40 on: November 15, 2017, 04:43:22 pm »
Did you mean N1MM?
Yes, thanks. Corrected the original post.
--73
« Reply #41 on: November 15, 2017, 04:49:07 pm »
When snap on ferrite work, they are great. Their suppression amount is tiny compared to a torroid, though. Remember the impedance increases with the square of the number of turns. So two turns through a torroid is like four snap ons. Seven turns in like 49 snap ons! Also the frequency shifts downwards with more turns. So you need more turns to shift it down towards 40 or 80 meters (~7 or 3.5 MHz).
The mix of the torroids is also important. Mix 31 is ideal for most of HF. Mix 43 can work ok at high frequencies. Google around and you will find charts of this. For my cable modem it took seventeen turns to get the noise out of 80m! For my cable telephone modem I hacked in an external linear supply, just feeding the voltage right onto the filter caps, bypassing the SMPS. That fixed that one quite well.
--73
Offline Hawke
« Reply #42 on: November 29, 2017, 08:06:02 am »
I have one of those in the box with manuals. Bought it in the 80s and never really used it then pulled it out 8 years ago to find the PCB splitting so it went to Sydney for a free refurb. They offered to fix it if they could use it for a few months afterwards on an internet relay so the rig sent and received data for 6 months and fed into the internet relay. Great radio for its time with sideband on 2 metres. Just another one I cant part with for some reason. Cheers
Offline CopperCone
  • *knock knock*
« Reply #43 on: November 30, 2017, 02:08:51 am »
are antennas filter enough, you would still want a mechanical filter to offer protection. SDR wont do shit for protection
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #44 on: August 15, 2018, 09:23:07 pm »
Suggestion: ICOM 7300. Almost idiot-proof, robust, user-friendly, good display, fun to use, worth the money
Offline PhilipPeake
« Reply #45 on: August 16, 2018, 04:53:21 pm »
I have been playing this game for a while (since 1978) so I do have a bit of practical, real-world experience, but just like everyone else, I have my preferences and prejudices, so you may well get conflicting (and equally valid) responses from others.
The #1 thing that turns people off ham radio is getting a technician (US terminology - basically license limited to VHF and above) license and buying a hand-held 2M/70cm transceiver. They quickly discover that its realistic range, to another of its kind is about half a mile unless both users stand on top of a large hill then the range can extend considerably.
So they are limited to repeaters. Most of these are perpetually dead. Those that are not are populated by groups of "old farts" that either ignore calls from anyone not in their group, or actively discourage other users of "their" repeater.
The transceiver gets tossed into a drawer and left there.
My advice is to spend a bit more money and get a 2M/70cm rig that is capable of SSB. Buy (or make!) a small beam, and mount it horizontally. You will easily get a range of 100+ miles. Much more under good conditions, with no repeaters involved. these rigs will also do FM, so you still have the repeaters and direct contact if you want it - you will need a second, vertical antenna for that (1/4 wave whip is fine).
Now, you said HF. Well, Don't go in there expecting around the world contacts. That mostly won't happen. ESPECIALLY without decent antennas. You really need space for a decent antenna. A 20M antenna isn't THAT big, and its a band that is a good balance between availability and propagation. Usually plenty of contact there too. A good place to start. Currently, the higher frequency bands (HF) are less interesting. the higher in frequency you go, the less activity/propagation. We need sunspots...
40m/80m are ok, too but the antennas start getting bigger.
A good antenna is key. All the expensive kit in the world won't help if you don't have a good antenna.
Built-in antenna tuners are ok, but they are really designed for an antenna that is tuned to somewhere in the band you are working, and it will adjust for miss-match as you move away from that "sweet spot". If you want to try to use a single antenna on multiple bands you will need something better, so put an decent antenna tuner somewhere on your list of things to get.
Now the rig itself ... I am an Icom fan, but that is just my prejudice. Others will tell you why their favorite is better.
I have an IC7000 (predecessor of the IC7200) that I used for ages, before treating myself to an IC7600 a few years ago (which is now back with Icom for repair). Either one of these, or anything in between is good. The 7300 seems like a good choice, although a 718 actually is pretty good too. Just less bells and whistles. As a beginner, those bells and whistles are really less important. Arguably they are not that important anyway. Filters? Well, maybe, if you like trying to dredge a mostly unintelligible signal out of the noise - some people like doing this, others less so. But before trying to do that spend some time on the antenna and grounding systems and that signal may suddenly not be buried in the noise any more.
Offline rhb
« Reply #46 on: August 17, 2018, 09:34:37 pm »
After much study I settled on a Yaesu FT-991A as a good compromise all around radio.  I still need to get relicensed, get antennae, etc.  So no real experience with the radio.  The other contender was the FT-817.
I hope eventually to put up 1/2 wave dipoles for 80 m and up, but will probably settle for a Cushcraft R9 to start with.  I'm next to a general aviation runway, so seriously height limited.
The 991A covers HF to 70 cm and would have a nice waterfall if Yaesu hadn't got it backward and shifted the waterfall rather than the tuned frequency indicator when the waterfall is running.  So when you see a weak signal and try to tune to it, it gets smeared so you can't see it.
Offline tkamiya
« Reply #47 on: August 17, 2018, 10:00:27 pm »
For a radio selection, my preference will be IC718.  Cheap, easy, and durable.  One can easily purchase an external antenna tuner.  Actually, that's better because what comes in the radio are unable to tune to make shift antenna he'll end up using in emergency situations.  Ultra small radios looks nice but many of them have problem in durability, even without rough treatment.
Having said that:
Before getting licensed and to buying equipment, I suggest your friend to go to a meeting of a local ARES/RACES group.  Most of them will welcome non-ham to sit in and learn.  That's the group that is primary "into" emergency communications" in United States.  "Communication" is a group activity.  He'll be working with, training with, and participating with the people he'll meet.  These group varies wildly.  I'd suggest making sure he will be able to welcome them as friends and vise versa.
