[x-post from QRZ forum]
Hi. This is my first serious R.F. project, so with very little or no background experience in building high power R.F. stuff, I'm looking for some feedback on this effort.
In the attached photo, there are the following components
1. A limeSDR USB in its own enclosure
2. It's TX output is connected to a 1W linear PA that I purchased from AliExpress a long time ago, and it has good performance
3. The small amplifier is connected to a MRF101AN based amplifier, and a tiny bias circuit (which has a diode thermally coupled to the MOSFET). This is capable of putting out 100W, and will be biased to run in class-A (hence the ginormous heat sink)
4. (Missing) The output of this big amplifier will go to a Bandpass filter
5. The big amplifier needs a 50V DC power supply, which I am using an off-the-shelf SMPS for
6. The small amplifier needs a 12V DC power supply, which I am using an off-the-shelf SMPS for
7. (Missing) I guess fuses in various places, and some power switches, and perhaps some LCD display modules for temperatures, voltages, etc.
I would like some feedback on
1. The R.F. part of the circuit.
2. The power supplies being used
3. Optimum design for an enclosure. Right now, I just used a wooden board as base since it was easy to screw things down to the board in case they need to be moved later. Once things become more final, then I can build a metal box for this.
4. Anything else glaringly obvious that I missed, and any other tips.
Thanks, and have a wonderful new year 2022
73 // VU2TVE
