I need to communicate 2 devices wirelessly, 1 or 1.5 meters away from each other. I just need to send a command, it means, I send HIGH value to receive HIGH value in the receiver, actually the transmitter side is a button.
The constraint is to use a pre-certified module to avoid a future process certifying it plus the money to get it certified.
Could you suggest the best RF module solution in terms of cost, consumption and simplicity?
Thanks in advance
