My first 6m band antenna was a magloop, aprox 35cm ring in diameter made of an 8mm copper tube
The mag loop is a difficult antenna, I would not recommend to mess with it unless you can tune it with a special High Voltage capacitor coupled with a fine remotely operated mechanical stepper.
The bandwidth is quite narrow and you have to tune it always precisely.
Otherwise it works, but its effectiveness is rather low (depends on its diameter vs the wavelength ratio).
Also mind the voltages and currents around the tuning capacitor are Huge (it is a high Quality LC circuit with a
LOT of kiloVolts RF around the tuning capacitor even with 100W into it).
