Loading [MathJax]/extensions/Safe.js
Author Topic: Matching RF power transistors  (Read 4361 times)
Offline kg4arnTopic starter
« on: August 05, 2017, 08:26:00 pm »
apologies if this has been previously discussed
How are RF power transistors matched, say for push pull service?
Offline dave_k
Re: Matching RF power transistors
« Reply #1 on: August 06, 2017, 12:33:22 am »
Generally for bi-polar transistors hFE (DC current gain) is measured, and for FETs forward trans-conductance and
gate threshold voltage is measured.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: August 06, 2017, 02:11:35 am »
For BJTs, Vbe is more important than hFE.  Connect B+C together, and measure at some constant current (say 1mA, or whatever a DMM's diode test does).  Beware that, if the transistor is oscillating in this configuration (for some reason), you'll get wrong numbers.
FET threshold is measured the same way (G+D tied, apply a constant current). :-+
Seven Transistor Labs, LLC
« Reply #3 on: August 06, 2017, 02:38:02 am »
Thanks. I will give it a try.
Offline BigBoss
« Reply #4 on: August 06, 2017, 08:58:00 am »
RF Power Transistor Matching is quite different than well known Complex Conjugate Matching. Because small signal conditions are not valid anymore.
You can do 2 things..
You obtain an accurate nonlinear model and you find Optimum Load Impedance ( this is not really accurate in reality) for that transistor in a professional RF simulator than you realize the matching circuit in according with..
or
You get Measured Load-Pull Data ( much more accurate if applicable) from the manufacturer and you realize  the matching circuit
« Reply #5 on: August 06, 2017, 11:18:58 am »
Quote from: kg4arn on Yesterday at 10:26:00 AM
or
Thanks.
I should have been clearer.
I was wondering how to match a pair of transistors to each other, like when you buy a matched pair.
For example, this is what I meant to ask about:  https://www.rfparts.com/catalogsearch/result/?q=MRF208
In this example they only charge a couple of extra dollars for the matched pair so the process couldn't have been too involved.
Ed
« Reply #6 on: August 06, 2017, 11:22:13 am »
Tim,
How close do you have to be?  10%, 20%, ??
Ed
Offline T3sl4co1l
« Reply #7 on: August 06, 2017, 12:14:15 pm »
Dunno, how close do you need to get? ;D
If it's for DC biasing, Vbe needs to be within maybe <10mV, otherwise current will be off by, well, about 60mV/decade, it's pretty sensitive, that exponential. ;D
Similarly for MOSFETs, but related to Vgs(th) and Gm.
And, as BigBoss mentioned, this is only DC parameters; whether you need tightly matched AC parameters, who knows.  If you need low THD and IMD (like a lot of radio base stations that use predistorted modulations), you might need to select through a lot of parts.  Other things (HAM radio?) probably aren't very sensitive.  YMMV.
Offline BigBoss
« Reply #8 on: August 06, 2017, 06:56:03 pm »
or
Thanks.
Ed
Himm.. You talk about "pair matching"..Sorry for misunderstanding..
The single way to match two RF Power Transistor is either to compare in terms of RF performance or request from the manufacturer-if applicable- selected devices.
It's not so easy but comparing DC Beta_Forward or measuring VBE threshold etc., wouldn't work.You cannot know how the intrinsic components will behave.
Or, you design a RF Power Amplifier with Alignment to compensate the differences ( for instance slightly different independent input-output network matching circuits,using shifted biasing etc)
Nevertheless, it's not possible to match %100 two RF Power Transistor, there will always be some imbalances..
