I need to measure some inductances, and I like using the nanoVNA (I do not own an LCR meter). One obvious way to measure an inductance with the nanoVNA is to connect it to Port 1, and see, at each frequency, the series R and series L as measured in the Smith Chart. However, I have found that these measurements are sometimes not very exact or reliable, I have found that the phase measurement is far more reliable and exact. So I have come up with a way to measure an inductance using the phase measurement in Port 1, and would like to share it, for anyone that finds it useful.
You connect a known coax cable to Port 1 (known Zo, velocity factor, and length). I use a small coax which came with the nanoVNA, with Zo=50 ohm, vf=0.66, l=0.215 m, and connect the inductance at its end. The nanoVNA is previoulsy calibrated in an adequate frequency range.
When the impedance as seen by the nanoVNA becomes infinite, the phase of \$\Gamma\$ is zero (and the Smith Chart crosses the x axis on the right of the chart). We can measure the frequency where this happens. The phase plot is like this:
At this frequency, all parameters are related in this equation: \$Z_o=wL\cdot tan\frac{w\cdot l}{v_p}\$, where you can calculate the inductance L. \$v_p\$ is the phase velocity, \$v_p={vf}\cdot c\$,and c is the speed of light in vacuum.
I have produced a list with various zero-phase frequencies and their corresponding inductances.
calcL.pdf (411.57 kB - downloaded 181 times.)
For example, I connect an inductance to my coax, and I measure with the nanoVNA a zero-phase frequency of 11 MHz. The inductance is then 9.6 uH.
You can change the frequency range and the coax length to measure different inductance ranges. This method allows the measurement of very small inductances: if you measure a zero-phase frequency of 175 MHz, the inductance is 18 nH. It provides good resolution at these small inductance values. I hope this is useful to somebody, at least it is to me.
