Author Topic: MLA-30 active loop antenna  (Read 75743 times)
Offline A.Z.Topic starter
  • if you can't measure it, you can't improve it
    • QRPer forum
Re: MLA-30 active loop antenna
« Reply #125 on: April 01, 2025, 07:55:31 am »
check this preamp
https://www.larches-cottage.co.uk/rx_antenna/preamps/Balanced_Loop_Preamp.pdf
no "wideband" and that alone solves a number of overload and noise issues :)
and then see
https://www.larches-cottage.co.uk/rx_antenna/loops_rx/loops.php
for some other ideas
HTH
    • QRPer forum
« Reply #126 on: April 01, 2025, 08:27:19 am »
check this preamp
and then see
HTH
for example, imagine using that varactor tuned preamp with the loop described here
https://www.larches-cottage.co.uk/rx_antenna/loops_rx/Evaluating%20a%20Broadband%20Active%20Loop%20Antenna.pdf
:D
    • QRPer forum
« Reply #127 on: April 02, 2025, 12:52:52 pm »
also see the tuned loop circuit found here
https://techlib.com/electronics/antennas.html
the circuit snd the loop are essy to build and offer acceptable perfirmance; alternatively, consider this circuit
https://www.arrl.org/files/file/QEX_Next_Issue/Jan-Feb2018/Steber.pdf
whi h can be applied to other RX antenna types :)
The following users thanked this post: TinkeringSteve
Offline TinkeringSteve
« Reply #128 on: April 02, 2025, 04:25:31 pm »
Tuning remotely with capacitive diodes, that's interesting, no clunky hardware. But still annoying :-D
Doesn't a tuned antenna kind of defeat the purpose of having a spectrum view/waterfall?
I guess a tuned antenna is good when there is broadband noise around, and / or the radio receiver is not selective enough?
« Last Edit: April 02, 2025, 04:27:54 pm by TinkeringSteve »
    • QRPer forum
« Reply #129 on: April 02, 2025, 08:59:42 pm »
remember that we're dealing with an "active" antenna so consider the antenna preamp too
and.. no, imVHo  a tuned stage doesn't defeat the purpose of  a spectrum/waterfall, think at it for a minute :)
« Last Edit: April 04, 2025, 10:48:45 am by A.Z. »
Offline vinlove
« Reply #130 on: April 24, 2025, 06:03:07 pm »
Is MLA30+ good DX antenna?  How does it compare with other antennas in performance?
    • QRPer forum
« Reply #131 on: April 24, 2025, 10:04:50 pm »
the MLA-30+ as is, when compared to other wideband active loops isn't a great performer, its only advantage is a quite low price, but then it falls really short due to a number of design faults amongst which the badly designed bias-t and the impedance mismatch between. the loop and the preamplifier .(and then there are others)
« Last Edit: April 25, 2025, 11:21:14 am by A.Z. »
Offline richnormand
« Reply #132 on: April 25, 2025, 12:43:37 am »
I have one.
I agree with A.Z. comments.
If you get rid of the of the PSU and substitute  a low noise  supply as described in the early postings here and mod the loop wire for a thin copper pipe. it is OK.
It is a price/performance depending on your goals.
In an urban area it is lower in noise compared to my regular dipole lower than 15MHz and is compact and discreet on a balcony.
« Last Edit: April 25, 2025, 12:58:18 am by richnormand »
Repair, Renew, Reuse, Recycle, Rebuild, Reduce, Recover, Repurpose, Restore, Refurbish, Recondition, Renovate
Offline coppercone2
  • √Y√... 📎
« Reply #133 on: April 25, 2025, 03:05:32 am »
you can try to disguise it as a peace symbol
Actually its one of the best covert antenna mods I have thought of. And theoretically it could also be disguised as B52 peace symbol.
« Last Edit: April 25, 2025, 03:09:53 am by coppercone2 »
    • QRPer forum
« Reply #134 on: April 25, 2025, 01:38:35 pm »
or, either, one may connect the preamp box of the MLA30 to an antenna like this one
https://hflink.com/antenna/#BBTDROOF
« Last Edit: April 25, 2025, 07:58:59 pm by A.Z. »
    • QRPer forum
« Reply #135 on: May 03, 2025, 11:31:59 am »
if one is familiar with DIY, a better loop
is the varactor tuned one designed by
Charles Wenzel and described here
https://sivantoledotech.wordpress.com/2010/09/18/a-tuned-active-receiving-loop/
performance will be MUCH better than
the one from that poor MLA30 an other
chinese loops like the "K480WLA" which
for a reason or another fall short from the
desired/possible performance level
https://www.reddit.com/r/shortwave/comments/1b1ilw7/new_active_loop_antenna_is_available_on_amazon/
https://www.amazon.com/GOOZEEZOO-K-480WLA-Shortwave-0-5MHz-500MHz-Battery%EF%BC%88Built/dp/B0CMD3LD9Z
« Last Edit: May 03, 2025, 07:46:56 pm by A.Z. »
The following users thanked this post: sab
