I've been assigned to make a bandpass filter as one of my semester projects for university.
I think designing it is no big deal but some questions have popped up along the way. I'm using
https://rf-tools.com/lc-filter/ to help me design this filter and ADS 2020 to test the design.
Basically i've noticed that stopband attenuation plays a big role in the filter design but in my case the stopband attenuation wasn't given, meaning that i have to choose it myself.
I don't have much experience in RF design so i don't know what level of attenuation is a good ballpark figure to base my filter off.
For example, the calculator linked above defaults to -50 dB, but i don't know whether it's normal or some pie in the sky figure. What's a common real-world number i should be aiming for?
Parameters are: center frequency 145 MHz, -3 dB at 144-146 MHz (passband), 5-th order, discrete components, FR-4 substrate, SMA plugs.
Impedances are not given but they'll be the standard 50
Also i'm not sure which type of filter to choose. At first i was leaning more towards elliptic or Chebyshev, but now i'm thinking more along the lines of Butterworth.
Problem with Butterworth is that the calculator gives me capacitor values in the femto Farrads and i don't think i can get my hands on those.
Some freedom is given in the filter design as long as the initial criteria is met so i think some microstrip action wouldn't hurt.
How hard would it be to design a discrete 490 fF or 151 fF capacitor on a PCB? I don't think stray inductance would be much of a problem given the µH inductors next to the fF caps.
