I’m working on this project with Russian/Soviet RF connector as I list in attach files.
To anyone who knew, please help me identify this connector.
Thanks in advance!
How close is it to a TNC?
I am looking at a TNC. Your connector is not a TNC.
TNC male looks almost identical to a BNC except it screws on, it does not lock on with a spring lock. It has a sharp machined pin with a conical tip, like a BNC.
Check dimension. Possible this is very old obsolete connector from GOST 20265-74
Thank you, sir. This standard totally matches my connector dimension!
It is quite large from the pix & spec sheet, & looks a lot like a Chinese L27 connector.
The latter are available from the PRC, but are not cheap.
