Author Topic: new scope capabilitys  (Read 2906 times)
Offline m3vuvTopic starter
« on: November 23, 2021, 06:04:08 am »
Hi all,ive just brought one of these cheap ,Hewlett Packard HP54503A 500MHz 4 Channel Digitizing Oscilloscope, just wondered if it will be capable of doing measurements on a 70cm tx/rx?. tia
Offline bob91343
Re: new scope capabilitys
« Reply #1 on: November 23, 2021, 06:27:37 am »
What are you trying to measure?
The following users thanked this post: m3vuv
« Reply #2 on: November 23, 2021, 06:55:05 am »
nothing at 70 cms,ive a deaf radio on 2mtrs ,i want to look at the rx signals and trace them,my other scope is 50 meggs bandwith so wondered if the new one is capable of doing this at 145 meggs.
Offline BrokenYugo
« Reply #3 on: November 23, 2021, 05:15:50 pm »
Google says it's not a true 500MHz, in that it will only handle that as a repetitive signal. So I guess it would work fine for usual inject a signal and see where it stops sort of troubleshooting.
Offline bob91343
« Reply #4 on: November 23, 2021, 08:20:25 pm »
I don't know that model.  I have a 54542A that works fine well past its claimed limit of 500 MHz.  In fact I measured around 650 MHz bandwidth, very high for what I do.
Having said that, it's seldom necessary to have a wide bandwidth scope to troubleshoot a receiver.  You put a signal in and first see if you have a corresponding IF signal.  If not, the problem is near the front end.  If so, it's later in the chain.  Those radios are almost always at least double conversion so there is a second mixer to investigate.
Offline max-bit
« Reply #5 on: November 30, 2021, 10:59:34 am »
As the oscilloscope has a 500 MHz band, it measures up to about 500 MHz (usually with a decrease of -3dB) but this is not a rule.
Offline MF-jockey
« Reply #6 on: November 30, 2021, 10:13:23 pm »
The probe plays an important role.
There are also nice videos from Dave
active probes
« Last Edit: November 30, 2021, 10:23:49 pm by MF-jockey »
Offline radiolistener
  • Country: ua
« Reply #7 on: December 01, 2021, 03:02:09 am »
At 400-500 MHz it's better to not use probes, but use RF connectors with coax cable. Because probes are working good bellow 100-200 MHz max.
