As an RF best ptactice , run separate grounding vias right next to each component that is grounded, do not run a bus grounded with a single via. And if space allows, make 2-3 grounding vias for each component.
When will be soldering, solder the SMA connector last, otherwise it will suck much of heat and you may have difficulties soldering other components close to it.
