Author Topic: Powerless radio  (Read 2688 times)
Offline ve7vieTopic starter
Powerless radio
« on: January 25, 2023, 03:56:19 am »
Offline Kim Christensen
Re: Powerless radio
« Reply #1 on: January 25, 2023, 06:24:48 am »
Sounds bogus, but if it did work as described, it's range would so short that it'd be useless.
Offline szoftveres
Re: Powerless radio
« Reply #2 on: January 25, 2023, 06:32:32 am »
The idea of a passive device communicating by modulating the surrounding RF field is not new, this is pretty much how RFIDs work. The RFID tags however are supplied by substantial RF power (relative to their power consumption) in order to be able to function and communicate.
Also https://en.m.wikipedia.org/wiki/The_Thing_(listening_device)
The LED demonstration in the video is 100% snake oil, they've essentially created two RFID devices, just don't show the RF power source in the video.
The small dipoles have to be supplied by a nearby RF power source (outside of the camera frame) transmitting at the resonant frequency of the dipoles for this demo to work, as opposed to the suggested "ambient backscatter" they claim to be using.
« Last Edit: January 25, 2023, 06:41:13 am by szoftveres »
Online Berni
  • Country: si
Re: Powerless radio
« Reply #3 on: January 25, 2023, 08:47:54 am »
This is same thing as backscatter radio. Nothing new there.
By switching a load resistor to the antenna terminals they are changing how much RF energy the antenna is reflecting. With the resistor connected the antenna takes in the radio waves and turns them into heat on the resistor, when the resistor is disconnected the RF power has nowhere to go, so it bounces back into the antenna and gets radiated back out. The other side then just measures how much power is being reflected back to it, getting the information out of it.
This is indeed what RFID does.
Offline james_s
Re: Powerless radio
« Reply #4 on: January 25, 2023, 08:50:55 am »
Seems like I read about a Cold War era passive espionage transmitter, I don't recall the details on how it worked but I'm sure there are some pages about it scattered around the web.
Online Ian.M
Re: Powerless radio
« Reply #5 on: January 25, 2023, 09:37:01 am »
The following users thanked this post: james_s
Offline yl3akb
  • Country: lv
Re: Powerless radio
« Reply #6 on: January 25, 2023, 10:06:33 am »
My first thought is that this experiment works because of good coupling between the directional horn antennas they use. It forms kind of beam waveguide, so that receive side is relatively strongly coupled to TX side and we get similar effects as TX and RX side would be connected with transmission line. And of course, if load is modulated at TX side, that slightly modulates gain and NF of RX LNA due to input mismatch which is detected as amplitude modulation. Input matching even doesnt have to be modulated - one can modulate noise temperature at TX side and that also would be detected as amplitude modulation (see the test with liquid nitrogen cooled resistor they mention in publication).
All this would not work in case of low gain antennas such as dipoles and other.
Offline tszaboo
Re: Powerless radio
« Reply #7 on: January 25, 2023, 10:21:09 am »
That's good, because a CR2032 battery that costs like 10 cents in quantity, and makes an RF transmitter work for years was really the bottleneck of such systems.  >:(
Offline jonpaul
Re: Powerless radio
« Reply #8 on: January 25, 2023, 10:29:01 am »
1960s USA Moscow embassy...
Soviet "gift" of seal OF USA, contained passive UHF cavity microphone eavesdropping device.
When illuminated by a beam of radio transmission at the cavity frequency, a réfection was emitted with sound modulated.
This the KGB, GRU, GPU, Spied on USA for many years before the mendacidty  of the Russkis was exposed.
Similaires to the laser beam off the window spy microphone.
Jon
Jean-Paul  the Internet Dinosaur
Online Berni
  • Country: si
Re: Powerless radio
« Reply #9 on: January 25, 2023, 10:36:52 am »
Yeah the issue with backscater like this is that the reflected signal sits right on top of the 'carrier', so it only works if the reflected signal is large enough to meaningfully change the amplitude of the large carrier signal back at the antenna transmitting it. Only way to get that is to have very good coupling between the antennas.
This is why RFID is very short range as it uses the same kind of principle of applying a load on the antenna coil. Sure there is a limit set by how much power the RFID tag electronics needs to harvest to actually work, but you can't actually build a massive 1 kW RFID reader and read tags from the next building. The tags electronics could harvest enough power, but the backscater signal would be so tiny that you couldn't make it out from the main power carrying signal that is being sent out.
The better way to do it would be to connect the backscatter antenna to a RF mixer and feed it a high frequency LO tone, this would mix the power carrying signal into side bands around it that leak back out of the mixer and back out the antenna. On the other side you can then filter out the power signals frequency and amplify up just the frequencies in the sidebands for much better receive sensitivity. But at this point this is more of a scavenged RF power powered active transmitter.
Offline yl3akb
  • Country: lv
Re: Powerless radio
« Reply #10 on: January 25, 2023, 10:59:00 am »
I dont think their experiment can be explained completely and compared with RFID, backscatter, 'The Things', etc. because all of them requires actively generated external RF signal, but their setup dont.
The following users thanked this post: Kim Christensen
Offline mawyatt
~Wyatt Labs by Mike~
Offline mawyatt
Re: Powerless radio
« Reply #12 on: January 25, 2023, 02:39:19 pm »
Jon
The "gift" feature was eventually uncovered because the US embassy was periodically being "illuminated" by high levels of RF/MW energy for unknown reasons, causing concern and eventual discovery. The technique was a coherent radar where the "audio" was encoded as phase modulation for the reflected return signal. Clever rendition of the well known remote laser "microphone".
Many devious and clever techniques were employed on both sides, likely still are  ;)
Best,
« Last Edit: January 25, 2023, 02:49:29 pm by mawyatt »
Offline jonpaul
Re: Powerless radio
« Reply #13 on: January 25, 2023, 03:01:39 pm »
"the Thing", invented by Léon Theramin, the same man with the 1930s valve touchless electronic instruments.
Pix of seal gift of Soviet schoolchildren ( and NKVD)
pix of Averel Harriman exposing the 7 years of Soviet violation of US Embassy at United Nations.
Jon
Offline Bud
Re: Powerless radio
« Reply #14 on: January 25, 2023, 05:37:56 pm »
Is that a cooking oil container that they in the article used for the cavity ?  :D
Offline joeqsmith
Re: Powerless radio
« Reply #15 on: January 25, 2023, 08:31:50 pm »
See https://theconversation.com/device-transmits-radio-waves-with-almost-no-power-without-violating-the-laws-of-physics-196271
Including the 'ambient backscatter' video linked there.
Opinions?
Each amplifier has a typical gain of 42.  They bandpass at 1.4G.   Guessing the waveguide using TE20.   Noise level at 27C for a 50 ohm resistor would be around -90dBm.  The ADG90x switch has an isolation of around -30dB at 1.4G.
Maybe fooling themselves by seeing a signal but caused by the switch and driver rather than the resistor's noise?   Maybe they could remove all the electronics from the transmitter side.  Run just their fixed resistor and rotate the antenna.
Interesting but have my doubts.  I would just write the author.  Maybe they could explain additional tests they performed to prove it out.
Along same lines but rather than rotate the source, leave the antenna stationary and just run it with an open and with the terminator manually inserted.   Of course, no other changes from their test when using the switch and driver circuit.
« Last Edit: January 25, 2023, 09:19:17 pm by joeqsmith »
Offline rfeecs
Re: Powerless radio
« Reply #16 on: January 25, 2023, 09:10:40 pm »
This is not ambient backscatter.
This is similar to what goes on in "cold source noise figure measurement".
Changing the source impedance (by using the switch) is just creating a mismatch that changes the noise power received.
The following users thanked this post: yl3akb
Offline rfeecs
Re: Powerless radio
« Reply #17 on: January 25, 2023, 09:33:21 pm »
Consider measuring the noise power out of an LNA with the input connected to a cable.  Measure the noise power with the cable connected to 50 ohms.  Then measure with the cable shorted.  The noise power will change.  So replace the cable with an antenna link.  That's all that is happening here.
Offline joeqsmith
Re: Powerless radio
« Reply #18 on: January 25, 2023, 09:57:15 pm »
Right, my question is if their paint thinner cans and cardboard horns have so much loss that what they are receiving is not actually the resistor's noise as claimed.  7.3 meters, with only a resistor at room temp for a source, maybe.
They did file for a provisional patent but I fail to see what is novel about the idea.  Yes, noise radiates.  Once published, we can have a look at the claims.
Offline Bud
Re: Powerless radio
« Reply #19 on: January 26, 2023, 07:44:50 pm »
Where do they get the power required to operate the switch?  :-//
What is the point of having a powereless transmitter if the power needed to operate the switch could instead be used to power the transmitter?  :-//
Offline antenna
Re: Powerless radio
« Reply #20 on: January 26, 2023, 08:00:29 pm »
There are posters like this in some cities.  There is a small detector that harvests a small amount of RF power from the antenna to run an audio chip that shorts the feed point of the antenna at an audio rate.  When you are listening to the same radio station the poster is tuned to, you can hear the audio from the poster over the broadcast signal. I have been wanting to build one of these for years now.
Offline joeqsmith
Re: Powerless radio
« Reply #21 on: January 26, 2023, 08:03:16 pm »
Apart from the energy needed to flip the switch, no other energy is needed to transmit the information. In our case, the switch is a transistor, an electrically controlled switch with no moving parts that consumes a minuscule amount of power.
Appears they used a solar cell and battery.
What is the point ...
Outside of being an interesting experiment and a source for discussion, I'm not sure.   Maybe the patent will add some insight.
Offline joeqsmith
Re: Powerless radio
« Reply #22 on: January 26, 2023, 08:07:38 pm »
I think you missed the point of the paper.  They claim to use a single resistor as a thermal noise source and modulate carrier using a mux that switches between the resistor and an open (or ground).   The only RF harvesting would be the receiver.
Offline antenna
Re: Powerless radio
« Reply #23 on: January 27, 2023, 09:09:31 am »
Are they heating the resistor with DC current or are they freezing their receiver?  The thermal noise in their receiver would be the same if not more otherwise, then add path loss....the dB's don't add up unless energy is put in elsewhere like cooling.   Are they dreaming of some miniaturized mesh network embedded in everything or something?  What else could be the goal there?
Offline joeqsmith
Re: Powerless radio
« Reply #24 on: January 27, 2023, 12:24:59 pm »
Nether.  Performed at room temp.
