Author Topic: RF delay line for 1.5 GHz to 4 GHz  (Read 4288 times)
Offline p.francksTopic starter
« on: March 09, 2023, 08:07:20 pm »
Dear all,
I am looking for a "true time delay" line for microwave pulses from 1.5 GHz to 4 GHz. I am looking for something that is programmable via TTL with switching times < 2 us and a max delay of around 1 ns and a step size < 150 ps. Can you recommend me any module that can do that?
Thanks!
Peter
Offline f4eru
    • Chargehanger
Re: RF delay line for 1.5 GHz to 4 GHz
« Reply #1 on: March 09, 2023, 09:44:20 pm »
that spec looks more like a phase shift.
What do you try to achieve on which signals ?
Offline TimFox
« Reply #2 on: March 09, 2023, 10:44:05 pm »
« Reply #3 on: March 09, 2023, 11:50:57 pm »
I have (square) pulses at a carrier frequency typically ~2-3 GHz that are ~10 ns long that I want to delay with respect to a second signal issued from the same pulse generator. I want to control the relative timing of these two signals in steps up to 1 ns. The application is for some magnetic resonance experiment.
« Last Edit: March 09, 2023, 11:52:30 pm by p.francks »
Offline Gerhard_dk4xp
« Reply #4 on: March 10, 2023, 12:22:00 am »
I have made a switchable delay line of 3 ranks of
( 1:6 SMA relay, variable lengths of semi rigid coax, 6:1 SMA relay).
It has 3 rotary switches and can bring everything between 4  and >100 MHz
into phase quadrature with the help of a power splitter, for measuring
phase noise. When the delay line was done, I bought a commercial
phase noise analyzer.  :-DD
I also have two motor-driven "Arra, Inc" 9228A-28 delay lines for microwaves.
The switching speed of all that is some decades slower than what
you need.
Cheers, Gerhard
« Last Edit: March 10, 2023, 12:29:12 am by Gerhard_dk4xp »
« Reply #5 on: March 10, 2023, 12:24:43 am »
Thank you very much! Yes, fast switching is really necessary. After some more research, in principle something like this would be ideal
http://www.gigabaudics.com/PADL6/padl6.html
However, this company seems to be inactive by now  :'(
Therefore I am asking? Do you know any other vendor for such a device?
Offline Chat GPT
« Reply #6 on: March 10, 2023, 10:32:02 am »
One option for a "true time delay" line for microwave pulses in that frequency range could be a digitally programmable delay line (DPDL). These modules are designed to provide precise, programmable delays to microwave signals and are commonly used in radar and communications systems.
One example of a DPDL that meets your specifications is the Hittite HMC649LP6. This module operates from 1.5 GHz to 4 GHz and provides a programmable delay range of 0 ns to 7.5 ns with a step size of 150 ps. It has a switching time of 1.5 us and is programmable via TTL.
Other manufacturers, such as Mini-Circuits, Analog Devices, and Peregrine Semiconductor, also offer DPDLs that may meet your requirements. It's worth researching and comparing different options to find the best fit for your application.
« Reply #7 on: March 10, 2023, 05:47:02 pm »
Thank you very much for the reply. The HMC649LP6 seems to be a phase shifter for 3-6 GHz or did I pick the wrong device?
https://www.analog.com/media/en/technical-documentation/data-sheets/hmc649.pdf
A more general question: Would a phase shifter also work? From a pure physics point of view a phase shift is a delay but I don’t know how these devices behave for pulses that have a spectral width of here 500 MHz.
Thanks for your help again!
Peter
Offline Marco
« Reply #8 on: March 10, 2023, 05:57:04 pm »
This answer feels a bit GPT.
Online gf
« Reply #9 on: March 10, 2023, 08:50:55 pm »
Delay corresponds to a freqency dependent phase shift, i.e. phase(f) = 2*pi*f*delay.
« Reply #10 on: March 10, 2023, 10:48:33 pm »
Yes, I get that. Maybe I should have posed the question more specifically: How is a phase shifter actually working? Is it really a delay (then it would be fine) or does it adjust the phase otherwise? Because if it is constant phase regardless of the frequency, then I will run into a problem for a pulse as this consists out of multiple frequencies. Multiple spectral components will then have different delays... Next problem is that a 360° phase shifter is only 500 ns at 2 GHz. So one would need to daisy chain.
Nonetheless, I am still on the hunt for something suitable for my delay. I find a lot of research articles but not so many products.
Offline Marco
« Reply #11 on: March 11, 2023, 09:01:04 pm »
This Russian page has a nice list of products.
Offline TimFox
« Reply #12 on: March 11, 2023, 09:12:55 pm »
A delay line has a constant time delay from input to output, and the phase shift for a sine wave will follow the equations given above.
A simple example of a constant 1.5 ns delay is approximately 30 cm of RG-58/U coaxial cable, properly terminated.
There are other ways to get a phase shift, which will have a different relationship between frequency and phase, such as a filter of various kinds.
