The skip zone varies by frequency and time quite substantially. Also, your ground is important, that is half of your antenna.
Use a length of coax to connect your antenna to your receiver, with the center going to the antenna, and the shield going to a groun or counterpoise.
Right now I am listening to lots of CW activity on 40 meters, just a bit above 7 MHz..
Another good receiver testing tool, is the digital modes program WSJT-X. Once your receiver is operational.
You can always hear digital modes at 7.076-7.079 or so at night and 14.076-79 daytime. Different digital modes have different characteristic sounds.
Something sounds badly mis-connected. A bad cable, most likely. Check that first. For continuity.
HF is more like DC than like UHF/VHF. You can even use speaker wire instead of coax, in a pinch, if you make sure to observe polarity re ground side. It works surprisingly well. (Characteristic impedance is typically around 90-100 ohms.)
Do you have any big variable capacitors lying around, we'll get you receiving stuff.
Is it night where you live now? Honestly, you should always be able to receive quite a bit at all hours of day or night.
to see what's happening in terms of propagation, go to
https://www.pskreporter.info/pskmap.html - look at their map.
Then zoom in on wherever you are and look at what QSOs are happening with your neighbors, you should, with a little bit of work, be able to receive some of the same signals on the same frequencies. Read up a bit on radio propagation.
It varies a lot. There is something called the "MUF" - the "maximum usable frequency" - which goes up in the daytime and down at night. Signals travel farthest closer to, but not above the MUF.
Bands below 10 MHz generally will be better at night, and those above 10 MHz in the daytime. Right around sunset and dawn, are the best chances to hear signals that have traveled for very long distances.
Also, bookmark
http://www.short-wave.info/index.php here is another good resource, in a more readable format..
http://www.dxing.com/tuning.htmIs there a lot of noise where you live? If so, then you may need a different approach. One that decouples your receiver from the (often common mode) noise.
Do you have any RF-appropriate toroids lying around? Or even an old 4:1 TV balun, that might be helpful for its binocular core- to isolate your antenna from power noise, etc.
You can buy a toroid which you can use in one for a few pennies here:
http://www.kitsandparts.com/toroids.phpYou will also need a few inches of wire. No need to spend any more.
if you have a toroid, you can make a "9:1 unun" to better match the impedance of your wire antenna to the receiver. Put the roroid near your antenna.
if you have a binocular core, we might as well make a balun.
If you have a fairly decent variable capacitor, and some wire, and a bit of coax you can use to run the signal to your radio, you can make a quick
magnetic loop.
If your radio cannot receive lots of stuff with a decent antenna, you got a bum unit, and if so, you should get an RMA then, and send it back.
HF is crowded, especially at night - and barring some solar disturbance, almost everywhere you look there is stuff.
