for example, you can use this RF mixer module:
https://www.aliexpress.com/item/32798750251.htmlthis mixer have 10 dB amplifier and allows to listen for any frequency from 0 Hz to 500 MHz. If you want to listen for higher frequencies, you're needs another mixer for GHz range.
Just connect:
- RFin to the antenna
- IFout to the sound card input
- LOin to the generator
You can use some cheap amateur generator like PSG9080 / FY6600 / UTG962 as LO source. Also you can use some more cheap Chinese RF generator module like si5351 and other. You're needs any RF generator which can produce stable frequency near the frequency which you want to listen.
How it works: you're put some RF frequency to LO input of the mixer and the mixer shifts frequencies down from that frequency. For example if you put 7000 kHz on LO input, then you can listen 7020 kHz station at 20 kHz. It shifts all frequencies from 7000 kHz to zero (DC). So, you will be able to receive it with usual sound card on any PC.
Just use HDSDR software and select sound card as input.
I recommend to use LO with signal level -20..-30 dBm (amplitude 10-30 mV) for AD831. If you use some CMOS generator with 3 Vpp output, just use
30-40 dB attenuator on the LO input. Note: SMA-male is the input and SMA-female is output for such attenuators, don't confuse otherwise the attenuator may burn out due to large amplitude. Such attenuator can handle max 2 W (amplitude 14 V) on the SMA male side, but I don't recommend to exceed 1 W (amplitude 10 V).
In order to improve reception quality, just add low pass filter with cut-off which corresponds to your sound card capabilities. For example, sound card which supports 192 kHz sample rate need LPF with cut-off below half of the sample rate. For 192 kHz it needs LPF with cut-off at about 80-90 kHz.
Also you can use BPF filter for desired frequency band on the RFin to improve dynamic range.
Of course, you can use LNA on the input to improve sensitivity, but ususal 16-24 bit sound card have good enough sensitivity to listen the radio at short wave (1-30 MHz).
