As it turns out, Starlink is soon about to get a compettition: Amazon's LEO.
What an apt name - LEO /Low Earth Orbit...
Yes, it's backed at the moment by far smaller satellite swarm (only 135), but it brings about at least two important changes:
- full-duplex communication wit the client. I..e just like wired Ethernet - ecah side can transmit while receiving and vice versa. This alone should do wonders for both bandwidth and latenncy.
- Much higher transfer speeds with one dish- 1000/400. Allegedly STarlink can get higher through multiple dishes and banwidth aggregation.
- Unlike Starlink, LEO doesn't just route client's traffic to the nearest terrestrial POP point, but through the satellite shel to its central terrestrial hub point. This brings all sorts of interestirng tradeoffs.
What I want to know how the hell did they pull the full-duplex trick off ? Is this normal for satcom, especially in a setup where one side uses small phased arrray gearr within a cheap, off-the-shelf equipment ?
How the hell do they get decent signal/noise ratio for that ?
Is this ever likely to compete with Starlink for mere mortals or will it remain just for uppper segments - like companiest etc ?
It seems that SpaceX has no plans to convert to full-duplex even after v3 hardware gets deployed.
I wonder why... 🙄
LEO is supposed to become operational for the public sometime in H1/2026...
