STF6N60M2
Common source
Vds = 100V
Id = 185mA
Rsrc = 5.6Ω (50 ohm generator, 3:1 Guanella style transmission line transformer)
Rload = 50Ω
Overall build. Bottom: 100V supply. Left: reflectance bridge. (Partial lie; this one isn't any good at high frequencies, so I changed to a Mini-Circuits ZFCD-10-1 which is reasonable at 200MHz.) Right: 20dB power attenuator. (Signal flow is left to right.)
Insertion gain (s21). Ref for all of these is bottom grid line (measured by difference). Not very impressive at high frequencies, but it's not optimized for any particular frequency. With a tuned load and better matching, I imagine the gain at high frequencies is quite reasonable (without sacrificing too much bandwidth).
Input return loss (s11). Coincidentally good match around 100MHz, implying Z_G ~ 5 ohms somewhere around there. Input impedance is higher at lower frequencies (match improves with resistor connected in parallel), as expected for a MOSFET gate which typically has a lossy-capacitor characteristic.
Feedback (s12). Quite low over most of the band, implying a reasonable margin towards maximum stable gain.
Note that this load is below the load line (i.e., 100V / 185mA = 540Ω), so the gain, as well as maximum power output, can be much higher than what's measured here. Just that the bandwidth is then crap.
Speaking of power and bandwidth: these transistors should be just about useless at low voltages. Coss is massive until about 30V. They should be treated more like vacuum tubes, actually: a relatively high saturation voltage, so plan accordingly in terms of [full-bandwidth] power output and load resistance.
The main downside is, the availability of power dissipation versus V*I ratings. These are switching transistors, of course. They are usually capable of DC SOA (amazingly, despite the reduced die area). But this transistor for example, 6A * 600V = 3600VA of switching capacity, but only 20W of power dissipation, so it's a long way off ideal.
This does make class AB PP amps a bit more favorable than class A. More stuff to put together (two or three TLTs for each balun), but vastly improved power output and efficiency.
