I need to find a PCB style 2.4GHz wifi antenna that radiates out perpendicular to the board, and, ideally already has a 12" length of coax on it with u.FL.IPEX (MHF4) connector on the end. I need to dbl-side tape the antenna to the side or top of a audio receiver unit that is in a tight location. I see many on amzon and the like, but most antenna stuff from there usually has bad VSWR.
Anyone ever use an antenna like this, something with decent VSWR <1.5? If so which one?
