Hello,
I understand a cheap passive field strength meter can be made of a couple of diodes, a capacitor, meter, and antenna, or better still, a multimeter with added small board.
also that this is good for relative measurements ie. it isn’t calibrated to tell you Watts or something, but may compare one antenna with another.
I aim to measure insertion loss of adapters added between a handheld transceiver and it’s antenna. Say when you have SMA on the handheld, but want to use a BNC antenna.
My understanding is that the insertion loss for such an adapter is negligible.
It occurs to me that a field strength meter could also measure any ill effect on VSWR presented to the handheld by adding adapters, as this would also ultimately reduce radiated power.
By all of the above logic, my understanding is that a field strength meter would expose any ill effect of using one or more of these adapters, or even a small coax between a HT and antenna.
To perform such tests, I plan to come up with jigs to clamp the meter and the DUT stationary so their antennas don’t move closer together between tests, etc.,
and also I believe the devices should be some distance apart so the meter’s antenna is not in the H field of the radiator, but other than that, they should be in the same room.
I’ve been accused of "devising tests to prove my own correctness instead of truly trying to question my own judgements”.
So am I leaving anything out here?
My predictions are that:
A) Adding an SMA to BNC adapter insertion loss would be <1dB, and not noticeable in any practical way for 2 meter band,
B) Adding an SMA to BNC adapter will not adversely affect VSWR presented to the HT.
Cheers
VK4JJY
