That's not a switch--
That's a switch!
https://commons.wikimedia.org/wiki/File:Two_pole_knife_switch.pngexcept that yours would be a DPDT type.
https://www.lockhaven.edu/~dsimanek/scenario/labman4/switches.htm"Frankenstein" switches are very good to use with balanced feeders.
I had an interesting experience, many years ago, when a temporary Radio Australia transmission was tried at my old workplace, using one of our existing HF broadcast transmitters.
A changeover knife switch was put in place, which when switched to the "RA" position put the transmitter on a Rhombic pointing to South Africa.
The normal routine was to turn off the Tx, call out " I'm going up to switch the aerial to the Radio Australia position".
I thought I was loud & clear enough, but when I reached the switch hut & operated the knife switch, it drew a huge blue arc.
I quickly slammed the switch back to its original position, & walked, shaken to the core, back to the main building.
It turned out that someone had some tests they wanted to do on the transmitter & turned the HT back on!
The Tx didn't even "grunt" when I opened the switch, & blithely continued to transmit 10kW through the nice blue "plasma" connection, for a fraction of a second the switch was open.
The switch showed no ill effects, either!
Smaller switches might not fare as well, so make sure your TX is off before changeover.
