Author Topic: using a drone to get an antenna up  (Read 3170 times)
Offline METopic starter
« on: April 27, 2025, 03:36:57 am »
has anyone tried using a drone to get a wire up instead of a antenna launcher etc?.
Offline Andy Chee
Re: using a drone to get an antenna up
« Reply #1 on: April 27, 2025, 03:45:50 am »
Yes
Online radiolistener
  • Country: Earth
« Reply #2 on: April 27, 2025, 05:40:53 pm »
at short waves drones are too noisy, so it can be useful to install the antenna, but using it as a flying antenna leads to a high noise floor.
Offline Andy Chee
« Reply #3 on: April 28, 2025, 04:29:53 am »
For a flying antenna, I would use a kite (if there's enough wind) or a helium balloon (alternatively, hydrogen is cheaper to purchase, but flammable)
Apart from RF noise, a flying drone antenna simply doesn't have the battery life for long radio operations.
Offline A.Z.
  • if you can't measure it, you can't improve it
    • QRPer forum
« Reply #4 on: April 28, 2025, 02:54:08 pm »
a hybrid system using balloons and drones would probably work better
Offline iMo
  • Country: li
« Reply #5 on: April 28, 2025, 03:26:35 pm »
I've been using a suitable rock..  :D
Offline A.Z.
    • QRPer forum
« Reply #6 on: April 29, 2025, 01:03:59 pm »
in the TRX ok, but using XTAL in the antenna ?!? :)
Offline n0xmz
    • N0XMZ Ham Radio Web Page
« Reply #7 on: May 06, 2025, 04:22:02 pm »
My next wire antenna installation will use a drone. Just tie some twine to it, fly it over a tree and land it on the other side. Tie the twine to stronger rope, tie the rope to the antenna, pull it all up and shazam! I used a slingshot for my G5RV Jr. but the next job will be a bit easier with the drone.
Offline incf
  • ASCII > UTF8
« Reply #8 on: May 07, 2025, 12:02:19 am »
how do you prevent the twine from getting caught in the blades while landing?
Test
Offline langwadt
« Reply #9 on: May 07, 2025, 12:06:45 am »
if you are pulling up a wire anyway just power it from the ground?
Offline Andy Chee
« Reply #10 on: May 07, 2025, 06:22:48 am »
I thought of that.
The I2R losses require thick copper wire for drone motor power supply.  The thick copper wire is heavy, requiring a bigger drone.  A bigger drone requires bigger motors.  Bigger motors means greater I2R losses, requiring even thicker and heavier wire.  The whole thing becomes too heavy.
You could avoid  I2R losses by sending high voltage, say 500V, then using a step-down converter onboard the drone.  Or the drone could fly using 500V brushless motors.
Offline A.Z.
    • QRPer forum
« Reply #11 on: May 07, 2025, 09:57:18 am »
I thought of that.
balloons for the lift, a drone to be able to "pilot" the balloons
I alteady wrote it, it's like an updated version of the ancient "airship" if you think at it for a moment
a " Drone Airship" would be even better or "blimp," if you prefer, the engines will only provide propulsion, the gas will ptovide the lift
just in case
https://www.rc-zeppelin.com/outdoor-rc-blimps-5m.html
:D
« Last Edit: May 07, 2025, 01:20:49 pm by A.Z. »
Offline Andy Chee
« Reply #12 on: May 11, 2025, 03:28:49 am »
I thought of that.
just in case
:D
My initial thoughts are that a blimp/dirigible large enough to lift a vertical wire HF antenna payload anchored to the ground, won’t necessarily require any station keeping steering on board.
a) there will be no wind, no need for station keeping propellors
b) there is high wind, the surface area of the blimp/dirigible will be too strong for the station keeping propellors.
c) there is medium wind, the ground anchor should be heavy enough to keep things in place
Offline Teledog
« Reply #13 on: May 15, 2025, 03:03:22 am »
NOTE: This message has been deleted by the forum moderator Simon for being against the forum rules and/or at the discretion of the moderator as being in the best interests of the forum community and the nature of the thread.
If you believe this to be in error, please contact the moderator involved.
An optional additional explanation is:
« Last Edit: May 15, 2025, 08:32:14 pm by Simon »
The following users thanked this post: BradC, Hamelec
