How well does this circuit work in practice, and can it be improved in any way? Are there any references anywhere to the theory behind how this works?Any thoughts?
Might be some ways to improve it, but I didn't built it in practice. About the theory behind that:
- the goal is to get a VCO (Voltage Controlled Oscillator) with a very linear frequency versus control voltage characteristic. F has to vary linearly with V because the VCO is used in a PLL (Phase Locked Loop) that will demodulate the FM signal. The PLL loop will try to keep the VCO in sync, which will create a control voltage (for the vco) that copies the audio signal from the transmitter. The more linear F with V in our VCO, the less deviations from teh original audio signal carried by FM (or else said, the less audio distortions), which is the final goal: Hi-Fi (High Fidelity) audio.
- a varactor (or varicap diode) is a diode junction reverse polarized. The more reverse voltage is applied, the more the gap inside the diode opens, the less capacitance it has. This is from the BB105B datasheet (the diode used in the FM tuner):
Note how the X axis (reverse voltage on the varicap) is logarithmic (logarithm is the inverse of an exponential), the Y axis (capacitance) is linear, and the slope is almost linear. That tells that capacitance decreases exponentially with the applied reverse voltage.
- a transistor is the BE diode (Base Emitter) with some additions, the BC junction (Base Collector), very roughly speaking, which means the BJT (Bipolar Junction Transistor) inherits the exponential behavior of a typical diode.
In this case, note how Ic (the collector current) grows exponentially with the Vbe (the base emitter voltage). The Ic is turned by the Rc into the reverse voltage that will control the varactor's capacity. The slide show picture is from
https://inst.eecs.berkeley.edu/~ee105/sp08/lectures/ in lecture 4 slide 11. The previous lectures might help, too, though those are only very brief slide-show presentation. That class follows the textbook 'Fundamentals of Microelectronics' by Behzad Razavi, Wiley Press, January 2008.
The frequency linearization idea from the initial VCO is to combine the two behaviors (exponential increase in the BJT current + exponential decrease of the varicap capacitance) in such a way thet the two exponential mostly compensate each other, and the C varicap will become linear with the Vbe applied on the transistor's BE.
There are more effects into play than only those 2 aspects (e.g. the transistor's internal capacitances), but I guess the exponential increase in Ic with Vbe + the exponential decrease of Cv with the VR (reversed voltage on the varactor) have the biggest contribution for F with V linearization.
However, the frequency of an LC tank does not vary linearly with C, so I guess the F range of interest is small enough (10.7MHz +/-75kHz), such that the quadratic variation of F with C doesn't matter. Or maybe it was compensated already by some other mechanism I am missing.
If not yet compensated, maybe inserting a FET (Field Effect Transistor) might help, because a FET has a quadratic behavior (similar with how a diode, or a BJT, has an exponential behavior).
