Author Topic: Which Battery Cable size  (Read 1312 times)
Offline veedub565Topic starter
« on: March 11, 2022, 04:52:38 pm »
I want to operate my vintage military HF rig from a leisure battery. It is 250W max output, with a rated max power consumption of 640W (CW, key down. )
So I reckon 640W at 12V is around 50A.
Question is which wire guage is appropriate. I did a bit of research and came up with AWG 4. Just looking for an extra opinion on whether that sounds about right.
I'm not actually going to be using it at full power. Indeed I'm only an M7 so 10W max. And even then I use SSB not CW. I thought it prudent though to set things up for what the rig is potentially capable of. Rather than what I use it for now, and then have to upgrade it later.
Offline TimFox
Re: Which Battery Cable size
« Reply #1 on: March 11, 2022, 05:18:39 pm »
How long a cable do you need?  Probably the voltage drop is a more important consideration than wire current rating.
Offline geggi1
« Reply #2 on: March 11, 2022, 10:35:28 pm »
If the cable is very short (1m) 10mm2 would be sufficiant.
In case the cable lis longer go for 16mm2 but keep it as short as possible.
« Reply #3 on: March 12, 2022, 07:17:46 am »
Thanks, its probably only going to be a couple of meters tops.
Offline Dehv
« Reply #4 on: March 30, 2022, 09:45:52 pm »
#4 sounds right, with a fuse compensating for increased amps due to voltage sag as the battery gets down to 10.5v.
The following users thanked this post: veedub565
« Reply #5 on: April 01, 2022, 05:13:21 pm »
Yes that's a good point, as the battery voltage drops it's gonna suck more current to compensate. I hadn't thought of that. I haven't actually gotten around to doing this yet, various other things taking up my time.
