Author Topic: Hardware Router VPN  (Read 25903 times)
0 Members and 34 Guests are viewing this topic.
Online Monkeh
Re: Hardware Router VPN
« Reply #100 on: July 09, 2025, 01:29:58 am »
Setting up a serious network appliance of any sort is quite possibly biting off more than you want to chew.
What's the actual reason behind wanting to have all your devices routed out of country? It's bound to cause headaches and broken services, and be far more annoying to disable as needed, so what's the actual goal?
Offline gnif
  • Views and opinions are my own
« Reply #101 on: July 09, 2025, 01:31:41 am »
Thanks.
So what you telling me is to just install a VPN software service on every machine and enable/disable as required, and anything else it too hard ;D
For this use case, yes, but not because it's too hard, but more because I think you wont be happy with the results.
Offline EEVblogTopic starter
« Reply #102 on: July 09, 2025, 01:48:20 am »
Thanks.
Yep, I suspect so too. Thanks.
« Reply #103 on: July 09, 2025, 01:50:29 am »
I just thought it would be cool and simple in the long term, done once and never having to ever worry about an issue with any one machine. But I now realise that's not the case.
« Reply #104 on: July 09, 2025, 05:07:37 am »
So, as an aside, should I opt out of this carrier grade NAT for my lab connection?
It says I have a fixed IP as part of my plan, but my AC1200 router says I have a Dynamic IP
Am I right in that a fixed IP will allow me to then change the DNS manually to 8.8.8.8 as suggested by gnif?
As currently the DNS can't be changed with the router set to Dynamic IP.
« Last Edit: July 09, 2025, 05:17:40 am by EEVblog »
Offline gnif
« Reply #105 on: July 09, 2025, 05:37:05 am »
This just means you're using NAT, if you don't want to remote connect to your lab, or host services there such as a server, then you can leave it enabled as it does give you some level of protection as you don't have a real IP to expose.
As for the DNS, no this wont help you here. If your router has DHCP settings it might let you configure the DNS server that it tells your network to use, the setting you're looking at is for the router device itself (or both if it's not changeable in the DHCP settings).
If the router doesn't give you enough control, you can do this per PC:
1) Click edit DNS server assignment in the Ethernet settings:
2611903-0
2) Select manual:
2611895-1
3) Turn on IPv4:
2611899-2
Don't worry about IPv6, its highly doubtful your ISP provides this, AU is very backwards with IPv6 support still.
« Last Edit: July 09, 2025, 05:44:01 am by gnif »
« Reply #106 on: July 09, 2025, 05:51:15 am »
Ah, I see it now in the router. Worth putting in the 8.8.8.8 or whatever?
Offline gnif
« Reply #107 on: July 09, 2025, 05:53:56 am »
I would if only to stop your ISP spying on your DNS queries
« Reply #108 on: July 09, 2025, 05:55:24 am »
Aussie support it it seems.
I have two IPv6 addresses, one /48 and one /64, plus one normal IP address
There is an Edit IPv6 Delegation button
« Reply #109 on: July 09, 2025, 06:01:17 am »
Done. 8.8.8.8 for primary and 1.1.1.1 for secondary. How do I check that it's worked?
« Last Edit: July 09, 2025, 06:04:26 am by EEVblog »
Offline gnif
« Reply #110 on: July 09, 2025, 06:05:00 am »
In windows run `ipconfig` in a terminal and you should see the DNS server as 8.8.8.8, if it's not, just renew the IP address (ipconfig /renew), or reboot.
« Reply #111 on: July 09, 2025, 06:22:51 am »
Nope, " Connection-specific DNS Suffix" is blank.
No 8.8.8.8 or 1.1.1.1 or other mention of DNS
Offline 5U4GB
« Reply #112 on: July 09, 2025, 07:39:18 am »
No.  Maybe they've finally fixed it but Google's DNS used to be location-moronic so it would direct you to servers located wherever it felt like rather than fast local ones, to the point where some sites became inaccessible depending on where it sent you at the time of the lookup.
And for the other reply above, about worrying about your ISP spying on you: You're suggesting that the solution to concerns about your local ISP, who in practice doesn't give a toss about your DNS lookups, is to hand your queries to the world's largest and most comprehensive surveillance platform instead?  I specifically send my DNS queries to my local ISP because they're the least likely to care about them.
Offline 5U4GB
« Reply #113 on: July 09, 2025, 07:40:42 am »
[snark]When you start seeing intermittent site outages caused by Google DNS you'll know it's working.[/snark]
Online Monkeh
« Reply #114 on: July 09, 2025, 08:17:24 am »
Unlike Google or Cloudflare, your local ISP can be and probably is legally required to log your queries and filter them according to the wishes of your government. When you're dealing with a government which genuinely believes the rule of law trumps mathematics or physics...
Online Monkeh
« Reply #115 on: July 09, 2025, 08:21:08 am »
Your router will be getting the IP via DHCP - it won't know whether it's being given a static assignment or not. If the IP is in the 100.64.0.0/10 range, then you're suffering CGNAT.
Offline 5U4GB
« Reply #116 on: July 09, 2025, 08:44:41 am »
Last I checked there was an opt-in blocklist of a small number of known CSAM sites and that was about as far as the ISP's responsibilities went.
Offline gnif
« Reply #117 on: July 09, 2025, 08:54:41 am »
Not much they can do if your using DNS over https, or encrypted DNS and a overseas DNS server. You can even rent a cheap VPS and throw bind on it for a personal DNS server if you want one you can trust.
As for spying on you, sorry, but the instant I start getting poisoned DNS records from a provider is the instant I lose all trust in them, government mandated or not.
« Last Edit: July 09, 2025, 08:56:52 am by gnif »
Offline madires
  • A qualified hobbyist ;)
« Reply #118 on: July 09, 2025, 11:16:33 am »
This is what Google says about logging DNS queries: https://developers.google.com/speed/public-dns/privacy
And Cloudflare: https://developers.cloudflare.com/1.1.1.1/privacy/public-dns-resolver/
Both log a lot.
Online Monkeh
« Reply #119 on: July 09, 2025, 05:46:42 pm »
Both log a lot.
And have you read those? I'll give a big hint: They don't store logs containing identifiable information.
Offline David Hess
  • DavidH
« Reply #120 on: July 09, 2025, 07:22:43 pm »
My OPNsense router is currently configured to block all outgoing UDP and TCP DNS requests to port 53.  DNS requests must go to the router, which then uses Unbound DNS to resolve all requests with DNS over TLS to port 853 of the usual suspects.  My VPN endpoints also resolve DNS through my local router.
I guess I should block port 853 also since browsers will commonly do their own encrypted DNS resolution if not properly configured.
Update: I already blocked port 853 when I originally blocked DNS.
« Last Edit: July 09, 2025, 08:52:32 pm by David Hess »
Online Monkeh
« Reply #121 on: July 09, 2025, 11:15:59 pm »
I presume with those rules that you do not currently have IPv6 connectivity..
« Reply #122 on: July 10, 2025, 01:56:25 am »
In that case it should fall back to the Cloudflare DNS right?
Offline gnif
« Reply #123 on: July 10, 2025, 02:08:38 am »
This is why you can set a primary and secondary, just set the secondary to cloudflare (1.1.1.1), if there is a fault it will automatically try the other server.
Offline 5U4GB
« Reply #124 on: July 10, 2025, 02:24:41 am »
Because then it's resistant to annoying subpoenas, while Google can still use all the other information it holds on you to de-anonymise as required.
You need to look at "privacy" statements from surveillance organisations like Google in terms of what they're protecting themselves from legally, not what rights they're pretending to leave you with.
