In mid-March, I found something interesting. "HEWLETT-PACKARD, unknown model."
I knew right away it was a 34401A.
It didn't even have a front bezel, and it was all cracked and dented.
The getter is still intact, so the VFD seems to be okay.
It's a gamble. This is my first 6-1/2!
I won the bid. 3,400 yen ($21).
It arrived. Just as I expected, it's all banged up.
On the top panel, it says "Mitsubishi Electric Corporation Communications Equipment Works". Looks like Mitsubishi tossed it out.
I'm a worried, but I'll try turning it on for now.
Bip. It powers on. Huh? It's starting to take measurements right away without any errors.
Still a bit confused by the differences in operation compared to the 3478A, I ran the self-test.
PASS!? What about the error log?
It's a bit of a letdown. It's in such bad condition, so I was sure it must have been discarded for a reason. It seems it was just thrown away.
First. I'm going to take it apart completely.
The VFD was barely hanging on. If it had been hit in the wrong spot, it would have definitely been toast.
The parts that need replacing are the front bezel, the keypad, the (non-existent) VFD window, and the rear bezel.
Somehow, all the capacitors and tantalum capacitors were still working. But I'm replacing them anyway. It's been 30 years, after all.
