Thank you
Converting
bitmaps/font_HD44780_cyr.h and
bitmaps/font_HD44780_int.h to UTF8 has solved it.
Device has booted. But calibration mode is not working. Device shows
component tester 1.34m on screen and it switches off
Edit: Solved it. There is a lever in config that can enable/disable calibration via probe short method
btw, can anyone tell me what causes efuse to fail in the
make fuses command
D:\component tester\ComponentTester-1.34m>make fuses
avrdude -c USBasp -B 10.0 -p m328p -P usb -U lfuse:w:0xf7:m -U hfuse:w:0xd9:m -U
efuse:w:0xfc:m
avrdude: set SCK frequency to 93750 Hz
avrdude: warning: cannot set sck period. please check for usbasp firmware update
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.03s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "0xf7"
avrdude: writing lfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xf7:
avrdude: load data lfuse data from input file 0xf7:
avrdude: input file 0xf7 contains 1 bytes
avrdude: reading on-chip lfuse data:
Reading | ################################################## | 100% 0.02s
avrdude: verifying ...
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0xd9"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xd9:
avrdude: load data hfuse data from input file 0xd9:
avrdude: input file 0xd9 contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xfc"
avrdude: writing efuse (1 bytes):
Writing | | 0% 0.00s ***faile
d;
Writing | ################################################## | 100% 0.08s
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xfc:
avrdude: load data efuse data from input file 0xfc:
avrdude: input file 0xfc contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: verification error, first mismatch at byte 0x0000
0xfc != 0x04
avrdude: verification error; content mismatch
avrdude: safemode: efuse changed! Was fc, and is now 4
Would you like this fuse to be changed back? [y/n] n
avrdude: safemode: Fuses OK
avrdude done. Thank you.
make: *** [fuses] Error 1Also, sometimes, when device is switched on with no component connected to probes, the display shows random values(T1-T2 130uF 60 ohm) and it keeps cycling with random values forever. What's going on?
