Interesting meter. Probably one of the cheapest I have seen with capacitance measurement. Most of the listings I have seen for these come with a yellow rubber case around it, though. Does this one not come with the case? I guess the ones that do cost extra, but seems like it would be worth the extra buck or two to get it with a case. The probes that come with it look like the super trashy kind that come with other similarly cheap meters.
The fact that it looks to have a "hard" on/off switch that physically disconnects the battery is a feature that I always really like. If it has an automatic shut off that's even better.
I don't see any range for temperature measurement or frequency on that meter, but it seems that there is also a DT9208A variant which has the 200mVAC range replaced with a temperature measurement mode and also has frequency measurement. Not sure if that variant mentions anything about an automatic shutoff, though. I tend to prefer meters with temperature measurement when available. That 200M resistance range is also unusually high for a handheld.
There is an article with several internal images here (it looks to have a glass fuse installed, LCD does not look adjustable). That said, it seems like these cheap meters often have multiple different board revisions floating around, so it's hard to be certain if the one you get will have a fuse or not.:
http://www.petervis.com/meters/Excel_DT9205A/Excel_DT9205A_Inside.html
Resistance (Ohm): 200, 2k, 20k, 200k, 2M, 20M, 200M, 2000M?
Capacitance (F): 2nF, 20nF, 200nF, 2uF, 200uF
Frequency: 2K, 20K, 200KHz
Temperature: -20?~1000?
As for the probes, just adding some hot glue can really help make them last longer (as they don't have proper support). It's a cheap solution that really helps. It won't do much about the resistance, however, it's difficult to expect some high end leads and those should last with the glue gun method (hopefully).
Instead of using hot glue, one might also use a couple layers of adhesive-lined heatshrink tubing instead. Done correctly, it can make for an excellent strain relief, and I know it is often used in industry to ruggedize things like higher-end and phase-stable RF coax assemblies.
The idea is to have multiple layers in such a way that the strain relief still flexes along its length, thereby actually increasing the bend radius rather than just shifting the strain point farther back like most rigid strain reliefs.
Edit: Added image. not the highest resolution, but you get the idea.
Yes, that sounds best as long as you can get the heatshrink over the probe (that is, if the size that goes over the probe is small enough so that it can shrink down nicely). Otherwise some soldering and hacking would be necessary. Glue gun is definitely not as good as that, but it's also not rigid, so it can somewhat do the same task up to a point.
I have the M version and have been using it for a few years. When I got it the probes fell apart after a few days, and of course they don't come apart so...not fixable. The bale broke off 6 months later of light and careful use, not after a drop. The AC volts range stopped working and seems unfixable. That said the meter is quite large and the display is easy to read. The on/off push button is a nice feature as you don't have to mess with the range switch to turn it off. Like all these cheap meters that use the chip mentioned it is remarkably accurate in all ranges including measuring capacitance. Continuity test is instantanious. It measures forward voltage in the milliamps in the diode check mode. On the milliohm range, the display floats and I don't think it really works. It's suppose to measure up to 20 amps but when I tested it, it seemed to top out about 10 or 11 amps, but that could be my lack of using a dummy load to check this.
I like this meter and after using it for some time I ordered another one from ebay with the Hz and temp settings. It also comes with an excellent English language manuel.
I think if you buy it and aren't disappointed when the probes break it will earn you respect.
They aren't too hard to pull apart. Clamp the front of the probe pin in a vice and twist the body of the probes to crack the overmold, and the pin pulls right out. From there, the heatshrink can be threaded on and the probe pin can be re-soldered (yes, it is just a single solder joint holding it, which is probably why they break so easily).
Just for laughs, I tried making these just now:
when the picture shows -1666 when the rotary switch is set to ACV with probes open.
Yes, I realize it is probably photoshopped by some clueless person, but it still doesn't inspire confidence.
