The wiring issue is interesting. The difference between the two pins is the OCXO Input and Output on the Blue Pill's MCU, which has a little 16MHz crystal connected there already.
Pin 5 is the Oscillator In, and Pin 6 is Oscillator Out on the MCU. So, what's actually happening when people think it works with the 10MHz OCXO connected to Pin 6? Is the 10MHz OCXO passing signal backwards through the 16MHz crystal? Is that even possible? Or is the 10MHz OCXO not actually connected?
Thanks,
Josh
