Author Topic: 10MHz GPSDO by "BH3SAP"  (Read 87698 times)
EU1 and 4 Guests are viewing this topic.
Offline Kurt_!
  • Country: at
Re: 10MHz GPSDO by "BH3SAP"
« Reply #725 on: September 14, 2025, 07:32:10 pm »
Ft232 Usb Uart (com7) Did not find any match for FA001....
Das zeigt Testcontroller an....
Habe die Baudrate auf 115200 und wieder auf 9600 gestellt
Oh...my English...
Online KungFuJoshTopic starter
  • TEAS is real.
« Reply #726 on: September 14, 2025, 07:41:29 pm »
Don't try TestController yet. You need to know if you can get a *IDN? response. The easiest way would be connecting to COM7 in Putty or something like that.
If you want to use TestController, it either needs a driver definition file, or you need to select scan serial ports and see if it shows anything.
Best Continuity Tester Ever
Offline Kurt_!
  • Country: at
« Reply #727 on: September 14, 2025, 07:52:57 pm »
I have a terminal program connected.
It spits out different numbers in FA000...
Ps.:
But only if I have the GPSDO connected...
« Last Edit: September 14, 2025, 07:57:42 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #728 on: September 14, 2025, 07:57:21 pm »
Can you copy and paste the exact response it gives to *IDN? ?
Offline Kurt_!
  • Country: at
« Reply #729 on: September 14, 2025, 08:15:08 pm »
I entered and sent....
117<\r><\n> FA0009999999.999600000<\r><\n> FA0009999999.999300000<\r><\n> FA0010000000.000100000<\r><\n> FA0009999999.999500000<\r><\n> FA0009999999.999500000<\r><\n> FA0009999999.999901960<\r><\n> FA0009999999.999901960<\r><\n> FA0010000000.000000000<\r><\n> FA0009999999.999800000<\r><\n> FA0009999999.999600000<\r><\n> FA0010000000.000500000<\r><\n> FA0010000000.000000000<\r><\n> FA00....
and so forth
It does not respond to commands
« Last Edit: September 14, 2025, 08:16:40 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #730 on: September 14, 2025, 08:23:12 pm »
Is that with a 10MHz signal applied? It looks like the current frequency listing activity.
« Last Edit: September 14, 2025, 08:25:23 pm by KungFuJosh »
Offline Kurt_!
  • Country: at
« Reply #731 on: September 14, 2025, 08:30:40 pm »
Yes, I think so too. It only happens when the GPSdo is connected.
They probably have a program for it. But where do I get it from?
Ps.:
I'll keep looking. The FA-2 is almost the same.
« Last Edit: September 14, 2025, 08:35:45 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #732 on: September 14, 2025, 08:36:03 pm »
It seems like you could use it with anything that can receive the serial data. Maybe even Excel, but I dunno. Worst case: log it in a terminal, copy and paste into Excel, and then chart it.
Offline Kurt_!
  • Country: at
« Reply #733 on: September 14, 2025, 08:47:06 pm »
I just found Timelab.....
It'll take a little while.
See you tomorrow.
Good night.
« Last Edit: September 14, 2025, 08:59:51 pm by Kurt_! »
Oh...my English...
Offline Kurt_!
  • Country: at
« Reply #734 on: September 15, 2025, 04:13:50 pm »
I don't think the Timelab is suitable.
Can you show me a diagram with the test controller and the small Dpsdo?
I also found the Lady Header, let's take a look...
Looking at your equipment, it's not bad!
Oh...my English...
  • TEAS is real.
« Reply #735 on: September 15, 2025, 05:08:52 pm »
You want me to run a test with the GPSDO on TestController? I'll set it up and run it soon.
Offline Kurt_!
  • Country: at
« Reply #736 on: September 15, 2025, 06:25:52 pm »
The FA-3 can do a bit too.
P-P, FIN, AVG, MAX, MIN...but not graphics yet.
I thought you already had it ready.
Because you mentioned a short fidgeting.
How big should it be? You want the comparison, right?
Oh...my English...
  • TEAS is real.
« Reply #737 on: September 15, 2025, 06:56:22 pm »
5 or 10 minutes when the stuff is well warmed up should be enough. You can do longer if you want.
I had to do the test over because I dunno if/where I saved the old screenshot. ;)
1 sec log time in TC, 1 second gate time on 53132A using the same GPSDO as an ext ref attached. I think it's a pretty good representation of what I expect. Note that the GPSDO being tested has a replacement ISOTEMP OCXO (age unknown) and I've had this GPSDO running constantly for about 6 days after the mods.
Thanks,
Josh
Offline Kurt_!
  • Country: at
« Reply #738 on: September 15, 2025, 08:42:58 pm »
Great. Too bad it doesn't work for me with the test controller.
But I got TimeLab running. Now I have to test it.
It evaluates the Fa... numbers.
Maybe the program will work for you too?
Oh...my English...
  • TEAS is real.
« Reply #739 on: September 15, 2025, 10:08:39 pm »
Which program doesn't matter. You can get  log data and see what the AVG, PP, and SD values are.
Offline ME
« Reply #740 on: September 16, 2025, 02:29:27 pm »
can i connect this bh3sap to my pc using a max 232 ic?
Offline Kurt_!
  • Country: at
« Reply #741 on: September 16, 2025, 02:30:28 pm »
A few questions for my very knowledgeable counterpart!?
Have you made any changes to the settings on the "small" GPS? Other than replacing the oscillator.
I think you can be satisfied with the values.
(Diagrams).
I'm testing Timelab. You can do a lot with the program. I've already saved a few diagrams...
There's still a lot to write!?
Oh...my English...
  • TEAS is real.
« Reply #742 on: September 16, 2025, 02:56:51 pm »
I have fredo_'s firmware v0.1.16. The settings adjustments made were to match the OCXO version, GPS module type, time zone, and baud rate of 38400.
Offline Kurt_!
  • Country: at
« Reply #743 on: September 16, 2025, 04:10:55 pm »
I have to change something there too.
I have everything set to standard.
It often adjusts according to the small one...
and so the frequency always goes up and down a bit (a few millihertz)...
Which isn't apparent on the big one, and on yours, either.
Der Kleine Ist mit int OSC..
Ps.:
Do you have one antenna or two?
https://www.eevblog.com/forum/Themes/default/scripts/advanced_uploader/images/uploader_icon.png
« Last Edit: September 16, 2025, 04:30:21 pm by Kurt_! »
Oh...my English...
  • TEAS is real.
« Reply #744 on: September 16, 2025, 04:27:12 pm »
One antenna. I got PP 3mHz using the SDG2122X with 1s gate/1s sampling. I'd expect better from the GPSDO directly.
Offline Kurt_!
  • Country: at
« Reply #745 on: September 16, 2025, 04:35:38 pm »
FA-3 cannot be trimmed more precisely. (Internal OSC)
Ps.:
The big one doesn't have that!
There is simply a difference whether internal or external!
The ups and downs remain for the little ones!
0.11 or 0.22 correction every few seconds!
You can see that on the chart.
« Last Edit: September 16, 2025, 05:42:44 pm by Kurt_! »
Oh...my English...
Offline ME
« Reply #746 on: September 16, 2025, 05:49:33 pm »
its so i can hook up the bluepill to my pc via rs-232 to look at the nema data etc, I wondered if the voltage levels from the bp pins that carry the sat data  will be convertwd to rs-232 levels with the max 232, i assume its ttl levels?, Thanks.
  • TEAS is real.
« Reply #747 on: September 16, 2025, 06:08:15 pm »
You should check the configuration for the lil guy. Those curves don't look right to me. On my first (shorter) screenshot, you can see more detail. Either way, I get around 600uHz PP, but no dramatic curve like yours shows.
What's the sample rate on your counter? What does the other GPSDO look like?
Offline Kurt_!
  • Country: at
« Reply #748 on: September 16, 2025, 06:32:04 pm »
It's best to buy an FTDI adapter or CP2102. They don't cost much...
Oh...my English...
The following users thanked this post: ME
Offline Kurt_!
  • Country: at
« Reply #749 on: September 16, 2025, 06:38:31 pm »
I'll have to take a closer look. The rate is per second. Maybe I need to adjust the 1.05 in the program.
Do you also have the corrections every few seconds: 0.00 - 0.11 - 0.22?
on the display.
Oh...my English...
