32KCoreStore and 3 Guests are viewing this topic.
I have a terminal program connected.It spits out different numbers in FA000...
I don't think the Timelab is suitable.Can you show me a diagram with the test controller and the small Dpsdo? I also found the Lady Header, let's take a look...
Looking at your equipment, it's not bad!
Which program doesn't matter. You can get log data and see what the AVG, PP, and SD values are.
its so i can hook up the bluepill to my pc via rs-232 to look at the nema data etc, I wondered if the voltage levels from the bp pins that carry the sat data will be convertwd to rs-232 levels with the max 232, i assume its ttl levels?, Thanks.
You should check the configuration for the lil guy. Those curves don't look right to me. On my first (shorter) screenshot, you can see more detail. Either way, I get around 600uHz PP, but no dramatic curve like yours shows. What's the sample rate on your counter? What does the other GPSDO look like?
